nstg8r Posted May 16, 2014 Share Posted May 16, 2014 How do these mount onto the roof? just wondering as I currently do not have one of these antenas. It bolts thru the roof, you would have to drill a hole since you don't have one. Link to comment Share on other sites More sharing options...
DrD123 Posted May 16, 2014 Author Share Posted May 16, 2014 Yup - you'd need to make a square hole in the roof for the antenna to fit in. The bottom of the antenna has a threaded portion that you thread a nut onto to hold it in place (the nut has a floating washer attached to it that locates the cable coming out of the antenna - see the pic below) - the hole is square to align the antenna (and then an o-ring seals to the hole, then there are ridges in the gasket that further seal to the roof so it doesn't leak) If you don't have it on your car, I wouldn't bother (if you are adding XM, just use one of the internal antennas) Link to comment Share on other sites More sharing options...
ebo03 Posted March 6, 2017 Share Posted March 6, 2017 Subscribed. Link to comment Share on other sites More sharing options...
