smithsrsn Posted February 17, 2012 Share Posted February 17, 2012 Just got my FX300 in the mail and the instructions state that the flywheel needs to have a .075" step machined on it. I am planning to use the OEM SMFW. Do I really need to have a step machined into the flywheel? Link to comment Share on other sites More sharing options...
KCwagon Posted February 18, 2012 Share Posted February 18, 2012 I have never heard of that. I am almost certain that this clutch and a factory flywheel works out of the box. Link to comment Share on other sites More sharing options...
smithsrsn Posted February 18, 2012 Author Share Posted February 18, 2012 The instructions also state that the warranty is void if the step is not correct. Perhaps the specs for the OEM SMFW also call for the .075 step. Hopefully someone will know the answer. If not, I will call Clutchmasters on Monday to find out their take on the subject. Link to comment Share on other sites More sharing options...
iNVAR Posted February 18, 2012 Share Posted February 18, 2012 http://forums.nasioc.com/forums/showthread.php?t=2208219 Just an update. I measured the step with a Mitutoyo depth micrometer and I am coming up with .080" step. So that what I am going to keep it at. It was actually .0815 but my depth mic is a bit out of calibration (.0015" off) so I took that away from the .0815". This sound about correct?I think it should work out of the box. edit: You can also your SMFW too being that you have one sitting there, right? http://legacygt.com/forums/showthread.php/just-fyi-photo-comparison-dual-mass-vs-single-mass-flywheels-129928.html Link to comment Share on other sites More sharing options...
smithsrsn Posted February 18, 2012 Author Share Posted February 18, 2012 I think it should work out of the box. edit: You can also your SMFW too being that you have one sitting there, right? I have one on order. I believe that the OEM SMFW probably has the .075 step as a factory spec. So if that is true then when my new one arrives then I should be able to use it out of the box. I will verify this with clutchmaster on Monday. I will also measure the step when my flywheel arrives. Link to comment Share on other sites More sharing options...
smithsrsn Posted March 15, 2012 Author Share Posted March 15, 2012 Just to close the loop on this thread, I did confirm that the factory flywheel does indeed have the correct .075 step and they do work straight out of the box. The clutch is very nice. I really like the light pedal feel and the clutch engagement is as smooth or more smooth than stock. The light pedal force seems to allow me to feel what the clutch/engine is doing rather than the heavy feel of the pressure plate springs. It is without a doubt my favorite upgrade so far. Link to comment Share on other sites More sharing options...
OutbackXT05 Posted March 19, 2012 Share Posted March 19, 2012 Good to hear. I just got my fx300 also and was wondering about the .75 step but now I know thanks Link to comment Share on other sites More sharing options...
