quick4dr Posted February 16, 2012 Share Posted February 16, 2012 So decelerating at approx 5mph to 0, i get a shutter. and small blipps of the throttle when moving in traffic. Checked for vacuum leaks all clear there, whats a torque converter job run for these things? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted February 20, 2012 Mega Users Share Posted February 20, 2012 Weird. Have you tried an ecu/tcu reset? It's possible that it's not a mechanical problem. I'd do that and then do an ATF drain and fill to see if it helps anything before thinking about opening up the torque converter. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 23, 2012 Share Posted February 23, 2012 What leads you to think it's the torque converter? Could easily be an engine problem. Does it do it in manual mode? [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
benena Posted May 14, 2014 Share Posted May 14, 2014 What leads you to think it's the torque converter? Could easily be an engine problem. Does it do it in manual mode? Sorry to revive an old thread. So what is it if it happens in manual mode and if it doesn't? thx. Link to comment Share on other sites More sharing options...
quick4dr Posted May 15, 2014 Author Share Posted May 15, 2014 update, my issue ended up being a fluid level was a bit high, and i needed to adjust my BOV VTA % and spring tension. Link to comment Share on other sites More sharing options...
