sreese185 Posted February 11, 2012 Share Posted February 11, 2012 Just put a Perrin TMIC on because my stocker split on me. Can someone take a look at this log for me please. Link to comment Share on other sites More sharing options...
sreese185 Posted February 11, 2012 Author Share Posted February 11, 2012 Logdatalog18.csv Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted February 12, 2012 Share Posted February 12, 2012 1. You have quite a bit of knock on the upper end. 2. You need a wideband o2 so that you know what your AFR's are up top. 3. Less is more. Log less stuff. I literally have 3x the resolution(3x as much data on a faster pull) because I log less. Here is a link on how to make useful logs courtesy of NSFW http://www.romraider.com/forum/viewtopic.php?f=33&t=5384 You don't need A/F Learning, A/F correction, Dynamic advance(H column), choose MAF volts or maf g/s you don't need both. Just a few pointers. The general log by NSFW is great for something like this, if you are looking for something specific, you can log other stuff. Less is more. Link to comment Share on other sites More sharing options...
sreese185 Posted February 12, 2012 Author Share Posted February 12, 2012 Where can you tell that I have knock on the upper end? Is this something to really concerned with? Link to comment Share on other sites More sharing options...
sreese185 Posted February 12, 2012 Author Share Posted February 12, 2012 Yeah I can see the feedback knock on the upper end is this dangerous? Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted February 12, 2012 Share Posted February 12, 2012 It can be yes. Generally, at lower loads and less than 2 degress(-2 feedback KC, lower rpms) is negligible/ignorable but at high load(ie. wide open throttle, at high RPM's) it needs to be addressed. What map are you running? Any tuning at all? Link to comment Share on other sites More sharing options...
sreese185 Posted February 12, 2012 Author Share Posted February 12, 2012 I just got a COBB 93 octane stage 1 map I have and up and dp that I still need to install then I was planning on getting a custom tune maybe from infamous. Link to comment Share on other sites More sharing options...
iNVAR Posted February 12, 2012 Share Posted February 12, 2012 Put on the 91 octane map and see what happens. Link to comment Share on other sites More sharing options...
ChefRacer Posted February 12, 2012 Share Posted February 12, 2012 What program do you use to read logs? Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted February 12, 2012 Share Posted February 12, 2012 To read the logs, Microsoft Excel. To datalog itself, I'm assuming that he is using the Cobb AP. Link to comment Share on other sites More sharing options...
sreese185 Posted February 12, 2012 Author Share Posted February 12, 2012 Yes I am using the COBB to Log. I am really thinking about getting a tactrix cable also for logging. Link to comment Share on other sites More sharing options...
cryo Posted February 12, 2012 Share Posted February 12, 2012 Yes I am using the COBB to Log. I am really thinking about getting a tactrix cable also for logging. Your accessport can log everything you need to log as long as its a V2. Like stated above you can use excel to open the logs and view them. I would agree to try the 91oct map. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
sreese185 Posted February 12, 2012 Author Share Posted February 12, 2012 Im going to switch maps today and see if the knock goes away on the top end. Thanks for all the advice. I will post a new log later. Link to comment Share on other sites More sharing options...
iNVAR Posted February 12, 2012 Share Posted February 12, 2012 Also, you don't need a tactrix if you decide you want to log with romraider. You have a 2005. You can get a $8 shipped vagcom cable from Ebay and it'l llog just fine. If you ever decide to go opensource, you'll need to use an older version of ECUflash though, but otherwise you'll be good to go! Link to comment Share on other sites More sharing options...
sreese185 Posted February 12, 2012 Author Share Posted February 12, 2012 knock is gone with the 91 octane mapdatalog19.csv Link to comment Share on other sites More sharing options...
iNVAR Posted February 12, 2012 Share Posted February 12, 2012 Fantastic! Do a few more logs for yourself just to make sure and if you're satisified, problem solved. Link to comment Share on other sites More sharing options...
sreese185 Posted February 12, 2012 Author Share Posted February 12, 2012 Yeah thanks for the advice!! The 93 octane gas must not actually be 93 then, so I will go with the 91 ocatane map just to stay on the safe side. I will do some more logs. When tuners look at the logs I hear 7-8 parameters is all that is needed what should I log with the AP V2 Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted February 13, 2012 Share Posted February 13, 2012 Depends what you are looking for. This page also applies to cobb logs. http://www.romraider.com/forum/viewtopic.php?f=33&t=5384 Link to comment Share on other sites More sharing options...
06_legacygt Posted February 15, 2012 Share Posted February 15, 2012 this mat help http://www.cobbtuning.com/info/?id=6167 2006 Legacy GT 5EAT Perrin UP, SPT CAI, OBXR CBE, Catless DP, Perrin TMIC, Stage 2 AP tune Soon after BNR 16G, Infamous Tune Link to comment Share on other sites More sharing options...
