GotTurboWut Posted February 17, 2012 Author Share Posted February 17, 2012 Both valve cover gaskets were replaced last week. Check engine light hasn't returned since my oil change. Would coolant burning cause white smoke? I want to keep this car... Link to comment Share on other sites More sharing options...
captainobvious Posted February 17, 2012 Share Posted February 17, 2012 Yep it would. I would check that coolant line on the side of the turbo. A slow drip will cause it to smoke and then when it is under pressure. I had the same think happen to me. It was coming out of the hood scoop when the car was sitting at idle after warming up. Link to comment Share on other sites More sharing options...
GotTurboWut Posted February 17, 2012 Author Share Posted February 17, 2012 Hope that's it. I started my car back up just a few minutes after getting home...Nothing, no smell at all coming through the vents at full blast and no smoke coming from the turbo area. Like you said, only after it's under pressure. I looked around the turbo and the lines but didn't see any leak. Link to comment Share on other sites More sharing options...
captainobvious Posted February 17, 2012 Share Posted February 17, 2012 A mechanic friend of mine was able to test it with it off. He put a pump over the rad cap and pumped it up and was able to see it seeping through the hose and dripping down. New clamp and the problem was solved. Hope its an easy fix for you as well. Link to comment Share on other sites More sharing options...
GotTurboWut Posted February 17, 2012 Author Share Posted February 17, 2012 That would be the best case scenario. In the past week, my car has been to an independant shop and Subaru dealership so it's definitely been torn down and put together recently (valve cover gaskets replaced). Something is still leaking b/c of this white smoke and smell coming through the vents. Link to comment Share on other sites More sharing options...
captainobvious Posted February 17, 2012 Share Posted February 17, 2012 Check that first. Bet your having the same issue. Who did your valve cover gaskets? Link to comment Share on other sites More sharing options...
GotTurboWut Posted February 17, 2012 Author Share Posted February 17, 2012 Monday appt at subaru barring this nor'easter snowstorm... Link to comment Share on other sites More sharing options...
GTTuner Posted February 17, 2012 Share Posted February 17, 2012 I see a lot of cracked turbo oil supply lines, they usually drip on the the up pipe and it burns off before it hits the ground. Link to comment Share on other sites More sharing options...
GotTurboWut Posted February 17, 2012 Author Share Posted February 17, 2012 I'm hoping it is just a coolant or oil line. Monday can't come soon enough. Just in case, again, looking at used vf 46's. New form subaru 1,150!! No way... Link to comment Share on other sites More sharing options...
captainobvious Posted February 18, 2012 Share Posted February 18, 2012 I bought a BNR 16g from Bryan on here cost me 760.00 with shipping. Its a direct bolt on replacement. Definitely worth it, i couldnt believe the price of turbos out there. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 18, 2012 Share Posted February 18, 2012 Monday appt at subaru barring this nor'easter snowstorm... What is the problem, don't you have AWD ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted February 18, 2012 Share Posted February 18, 2012 He mite have the RE92's still:spin: & just because he have AWD don't mean he can drive. . Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
GotTurboWut Posted February 19, 2012 Author Share Posted February 19, 2012 Sold car....had enough problems since I had it. Mods can close this thread. Link to comment Share on other sites More sharing options...
