lucas569 Posted February 16, 2012 Share Posted February 16, 2012 5th gen = end of lgt, there should honestly be a whole separate forum for fuglylegacy.com i kid i kid but it really lost my intirest After 09 Link to comment Share on other sites More sharing options...
frank_ster Posted February 16, 2012 Share Posted February 16, 2012 The low mounted turbo requiring a scavange pump kinds sucks Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ChefRacer Posted February 16, 2012 Share Posted February 16, 2012 But a low mounted turbo that doesn't heat up a tmic doesn't suck Link to comment Share on other sites More sharing options...
BigBlack-V Posted February 16, 2012 Share Posted February 16, 2012 spec.B vs. racecar I was 0. And I'm still a zero. Link to comment Share on other sites More sharing options...
frank_ster Posted February 16, 2012 Share Posted February 16, 2012 But a low mounted turbo that doesn't heat up a tmic doesn't suck Well it's not just the turbo location that heats the intercooler heat from the radiator fans and heat from exhaust travel up. But the major factor is the blow off valve that is open at idle. The turbo is hot it transfers heat to the air the turbo is actually pushing air even at idle the hot air is cooled by the intercooler then some is returned to the inlet of the turbo for reheating and a the rest is actually used by the engine So the low mounted turbo only reduces the radiant heat but thie intercooler will still get hot. On mine I tightened up te spring on the bov so that it's not bypassing at idle. I found this to help a lot maybe this is also done on the newer subarus also Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
