ColdBore Posted February 6, 2012 Share Posted February 6, 2012 Searched for awhile to no avail. Simple question i think, can anyone tell me or point me in the right direction on the site to the limit of the stock 5mt on the 08 LGT. Thanks in advanced. Link to comment Share on other sites More sharing options...
ericem Posted February 6, 2012 Share Posted February 6, 2012 Really comes down to how your driving it. Realistically I would not exceed 300ft-lbs of torque. Stage 2 is just fine on the stock 5mt. What are your goals? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 6, 2012 Share Posted February 6, 2012 It's more towards 350ftlbs, they say. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BAC5.2 Posted February 6, 2012 Share Posted February 6, 2012 Power limit? All depends on how you drive it. The LGT fares better than the older WRX's, for sure. There are guys making 350whp and 380ft-lbs without any real problem. If you don't launch, and don't shift like you are trying to break something, then you'll be fine for about that 350ft-lb mark with some degree of safety. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
bmx045 Posted February 6, 2012 Share Posted February 6, 2012 the lgt 5mt is pretty robust. the 09+ wrx has similar characteristics, my buddy has been running his 09 wrx at 370whp 390ftlb (mustang dyno) for a couple years now without a problem. Of course if you bang gears it will not last as long.... but the lgt gears in the 5mt are pretty tough Link to comment Share on other sites More sharing options...
ColdBore Posted February 6, 2012 Author Share Posted February 6, 2012 I don't have cemented goals,I just finished up the engine build now i'm worried about my vf46 pushing 18psi with 105k on it. So Im trying to decide on a turbo and accessory components quickly but m not trying to put in a new tranny..atleast not right now. Thanks for the info, it will certainly be of help Link to comment Share on other sites More sharing options...
bmx045 Posted February 6, 2012 Share Posted February 6, 2012 the 46 is good enough to handle 18psi, if there's no shaft play you shouldn't be worried. Link to comment Share on other sites More sharing options...
ColdBore Posted February 6, 2012 Author Share Posted February 6, 2012 Well I was fine until I left for work yesterday,I think I heard a metal/mechanical noise when I was driving,(im not sure music was up pretty loud) but I wasn't going hard on it. Im really busy all week do idk when I can pull the turbo so I've been driving really careful Link to comment Share on other sites More sharing options...
bmx045 Posted February 6, 2012 Share Posted February 6, 2012 hmmmm Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 6, 2012 Share Posted February 6, 2012 Power limit? All depends on how you drive it. The LGT fares better than the older WRX's, for sure. LALGT has 425wtq. Fixed:p Link to comment Share on other sites More sharing options...
Code Posted February 6, 2012 Share Posted February 6, 2012 Are you still running an oem-spec clutch? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
ColdBore Posted February 6, 2012 Author Share Posted February 6, 2012 So i'm going to guess 200 miles with shaft play would be really bad ( estimated miles i'm driving before I can pull it) Link to comment Share on other sites More sharing options...
ColdBore Posted February 6, 2012 Author Share Posted February 6, 2012 Negative, stage 1 exedy clutch and fly wheel. Brand new Link to comment Share on other sites More sharing options...
Code Posted February 6, 2012 Share Posted February 6, 2012 Depends on the amount of play. If there is contact with the turbine housing it may end up costing you a motor. If it's a slight amount of play it may be ok. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
ColdBore Posted February 6, 2012 Author Share Posted February 6, 2012 :mad:I just put the motor in Doesn't help I let my dad drive it for a day and he filled it up with 87. Maybe I'll pull it today Link to comment Share on other sites More sharing options...
CasopoliS Posted February 6, 2012 Share Posted February 6, 2012 :mad:I just put the motor in Doesn't help I let my dad drive it for a day and he filled it up with 87. Maybe I'll pull it today I would get rid of your dad. j/k - good luck with this situation. Link to comment Share on other sites More sharing options...
ColdBore Posted February 6, 2012 Author Share Posted February 6, 2012 Haha, I thought about it but he was trying to do me a favor by filling her up so I just thanked him. Thanks sir Link to comment Share on other sites More sharing options...
Max Capacity Posted February 6, 2012 Share Posted February 6, 2012 So i'm going to guess 200 miles with shaft play would be really bad ( estimated miles i'm driving before I can pull it) My vf40 began to whine for a while, then when it changed to a whistle I stopped driving the car and replaced it. I'd say it whined for a couple of hundred miles, if and when it whistles STOP driving it. You should also make sure you don't have any loose connections giving you a false noise... Oh I also ran 19psi on the vf40 for the previous two years or so with more miles then you have. see my sig. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ColdBore Posted February 6, 2012 Author Share Posted February 6, 2012 Casopolis, if my turbo is fine I may need some cubbypods, you make those right? Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 6, 2012 Share Posted February 6, 2012 Are you still running an oem-spec clutch? OF COURSE NOT. OP asked about the 5mt not the clutch itself but since you are asking I have ran OEM, exedy stage1 and COMP so far in my LGT. Link to comment Share on other sites More sharing options...
ColdBore Posted February 6, 2012 Author Share Posted February 6, 2012 Max cap , thanks for the reassurance, i'm probably just worrying to much Link to comment Share on other sites More sharing options...
Max Capacity Posted February 6, 2012 Share Posted February 6, 2012 Max cap , thanks for the reassurance, i'm probably just worrying to much I found some bolts loose on my vf52 a few months after I installed it, so check them first. Good Luck 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Code Posted February 6, 2012 Share Posted February 6, 2012 OF COURSE NOT. OP asked about the 5mt not the clutch itself but since you are asking I have ran OEM, exedy stage1 and COMP so far in my LGT. That was for OP. sorry for the confusion. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
