BadTouch Posted February 5, 2012 Share Posted February 5, 2012 I was driving my car last night and noticed a tiny rattle when I would shift down. Now today it is really bad! Even at an idle it will knock. I haven't had a chance to look in the oil pan to check for shavings. (Kinda scared to) The oil level is good. One of the pulleys on the front of the motor has a slight wobble to it. I don't no enough about em yet to no what one it is. It idles good and doesn't miss out so idk wut to do! Link to comment Share on other sites More sharing options...
BadTouch Posted February 5, 2012 Author Share Posted February 5, 2012 Its coming from the side that the timing belt is on. Could it be that? It has about 93,000 miles on it Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 5, 2012 Moderators Share Posted February 5, 2012 heat shield? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
ibr_adam09 Posted February 5, 2012 Share Posted February 5, 2012 Maybe an idler has gone bad ? Link to comment Share on other sites More sharing options...
BadTouch Posted February 5, 2012 Author Share Posted February 5, 2012 heat shield? Which one? Link to comment Share on other sites More sharing options...
BadTouch Posted February 5, 2012 Author Share Posted February 5, 2012 Maybe an idler has gone bad ? Possibly could be that i gess. Link to comment Share on other sites More sharing options...
BadTouch Posted February 5, 2012 Author Share Posted February 5, 2012 It gets louder and faster when I give it rpms Link to comment Share on other sites More sharing options...
adreyna Posted February 6, 2012 Share Posted February 6, 2012 That's make two of you. Here the link to an also recentlty posted threads and look at my first post. http://legacygt.com/forums/showthread.php/turbo-noise-idle-deceration-179250.html Link to comment Share on other sites More sharing options...
BadTouch Posted February 6, 2012 Author Share Posted February 6, 2012 Its a lot louder than in that video and it does it all the time. I had my mechanic listen to it last night he said it sounds like a broken spring in the top end. Its more of a tick I gess. And real metallic. Link to comment Share on other sites More sharing options...
adreyna Posted February 6, 2012 Share Posted February 6, 2012 take a video? Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted February 6, 2012 Mega Users Share Posted February 6, 2012 Check your accessory belts and look for carnage. With the idler pully wobbling like that its most likely tearing up the belts. When the accessory belts are torn up, it will cause a rattle and vibration like you are talking about. This just happened to me. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
