xt2005bonbon Posted January 20, 2012 Share Posted January 20, 2012 As the title says.. We have a banjo bolt filter on the driver side behind the timing belt cover. If that sucker gets clogged (even partially), what problems are we looking at or possible symptoms? AVCS not performing well thereby poor idling?? Link to comment Share on other sites More sharing options...
bmx045 Posted January 20, 2012 Share Posted January 20, 2012 OCV valve malfunction, but yes, avcs in actuality. might get a timing over advance CEL Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 20, 2012 Author Share Posted January 20, 2012 So that means people can get fooled by thinking their driver side OCV is kaput.. Link to comment Share on other sites More sharing options...
bmx045 Posted January 20, 2012 Share Posted January 20, 2012 yes. sometimes. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 20, 2012 Author Share Posted January 20, 2012 So, one can assume that whatever happens to that banjo bolt will not directly affect and/or kill the turbo, correct? Link to comment Share on other sites More sharing options...
bmx045 Posted January 20, 2012 Share Posted January 20, 2012 usually if there is debris in the oil it will kill both the turbo and ocv at the same time. the turbo banjo is separate from the ocv but like i said, if you gets clogged, the other is likely to be clogged as well since they're both fed by the same line from the back of the head. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 20, 2012 Share Posted January 20, 2012 Luckily most of us have survived with just the one filter removed. May be its where it is on the oil system. When I got the P0011 and P0021 CEL's my trusted mechanic said they remove the one in the passenger side head to fix the problem. In case you missed it, my turbo began to whine shortly there after. I replaced it before it blew. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
