00 Swag Posted January 13, 2012 Share Posted January 13, 2012 I'll do my best to describe this....... So the wagon has developed a shimmy / slight vibration. It only happens while in drive, completely stopped with foot on the brake. It goes away when in neutral or while in motion. It is progressively gettin worse. Now it seems I've developed a bit of a squeak from the rear end. It only happens in motion in speeds not exceeding 15 mph. Yanno, like creepin through a parking lot. 2000 BHD auto 177k miles. All fluids under the hood are good to go I don't like the ideas that pop into my head. Then again, my ideas don't amount to much. I am a cook not a mechanic. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted January 13, 2012 Share Posted January 13, 2012 Well it sounds like your transmission mount or motor mounts are getting worn down. That would cause the vibration at a stop light and when you shift it into neutral it lets off of a lot of the forces on those mounts so it settles. Mine does the same thing. Go to your back bumper and push down on it with some force. If it bounces 1-1/2 to 2 times then chances are your rear shocks are either bad or on their way out. If you do it and hear the squeak that's probably it. Link to comment Share on other sites More sharing options...
00 Swag Posted January 14, 2012 Author Share Posted January 14, 2012 Thank you, just realized I posted in wrong gen...I'll cheek those out. Link to comment Share on other sites More sharing options...
