Zac88 Posted January 8, 2012 Share Posted January 8, 2012 Looked around on the turbo inlet but couldnt find it. Search only brought up locations for older legacys. Where exactly is it? Link to comment Share on other sites More sharing options...
bmx045 Posted January 8, 2012 Share Posted January 8, 2012 its in the maf sensor, unscrew it with 2 phillipshead screws and you'll see the gum-drop looking sensor in there. Link to comment Share on other sites More sharing options...
Zac88 Posted January 8, 2012 Author Share Posted January 8, 2012 ahh ok. I cleaned my MAF and wanted to clean my IAT too but I guess its all the same then, thanks! Link to comment Share on other sites More sharing options...
bmx045 Posted January 8, 2012 Share Posted January 8, 2012 the maf heated airflow sensors are inside the maf tube in the sensor, the item you likely saw with your eyes is the iat. Link to comment Share on other sites More sharing options...
jhawk222 Posted January 10, 2012 Share Posted January 10, 2012 Just cleaned my IAT and MAF last week.....and yes BMX045 knows what he's talking about. Those two thin wires in the tube are your IAT. I almost missed them the fiirst time. Link to comment Share on other sites More sharing options...
bmx045 Posted January 10, 2012 Share Posted January 10, 2012 Just cleaned my IAT and MAF last week.....and yes BMX045 knows what he's talking about. Those two thin wires in the tube are your IAT. I almost missed them the fiirst time. the thin wires are your actual flow sensor, the brown balloon thing is the IAT. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 10, 2012 Share Posted January 10, 2012 the thin wires are your actual flow sensor, the brown balloon thing is the IAT. Great technical talk there.... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jhawk222 Posted January 10, 2012 Share Posted January 10, 2012 ^^^^ Hahaha to both of you....thanks for the clarification. Link to comment Share on other sites More sharing options...
jhawk222 Posted January 10, 2012 Share Posted January 10, 2012 And my balloon was Durrrrrty!! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 10, 2012 Share Posted January 10, 2012 So wasn't mine before I cleaned it, car ran much better when it was cold after the good cleaning. If you get CEL's after starting the car just clear them and you should be fine. I got one CEL for the MAF and one for the IAT. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
jhawk222 Posted January 10, 2012 Share Posted January 10, 2012 No CEL's after the cleaning either!! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 10, 2012 Share Posted January 10, 2012 Great. glad to hear that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
