JonnyWachter Posted January 4, 2012 Share Posted January 4, 2012 i was looking around for an up pipe and came across this, http://www.jdmcenter.com/product.html?id=subaru-legacy-gt-limited-02-07-ej20-ej25-header-up-pipe i have searched the forum and cant find anything on them. any suggestions? are they crap? for the price of a good up pipe, I could get headers also. Also i couldn't find much info on the OBX cat back exhaust, any experience, good or bad? how about sound? Link to comment Share on other sites More sharing options...
jhawk222 Posted January 4, 2012 Share Posted January 4, 2012 Personally not the biggest fan of the flex section header/up. That add screams buyer beware unless someone on here has one installed and can chime in otherwise. Just my .02$ Link to comment Share on other sites More sharing options...
JonnyWachter Posted January 4, 2012 Author Share Posted January 4, 2012 yea thats exactly why i posted the question. i was definitely cautious about it, but if it is a good piece then why not? Link to comment Share on other sites More sharing options...
TRSCobra Posted January 4, 2012 Share Posted January 4, 2012 I'd give you 6 months before that flex section comes apart from the inside and ruins your turbo... Link to comment Share on other sites More sharing options...
rweezy Posted January 4, 2012 Share Posted January 4, 2012 ^^ Agreed, that flex section looks like trouble waiting to happen. Doesn't take much to shred a turbo. Link to comment Share on other sites More sharing options...
TRSCobra Posted January 4, 2012 Share Posted January 4, 2012 Take a look at this one: http://forums.nasioc.com/forums/showpost.php?p=34703959&postcount=577 And it sells for more than the one you're looking at. Link to comment Share on other sites More sharing options...
JonnyWachter Posted January 4, 2012 Author Share Posted January 4, 2012 What if i were to get the flex joint removed and replaced with a solid bend? Link to comment Share on other sites More sharing options...
TRSCobra Posted January 4, 2012 Share Posted January 4, 2012 That header probably needs the flex joint to line the flanges up. If you bolt everything up, then cut it out and weld a solid piece in, it will fit. But it will eventually crack and leak anyways. A lot of work for something that gives little to no performance gain. Link to comment Share on other sites More sharing options...
JonnyWachter Posted January 4, 2012 Author Share Posted January 4, 2012 yea true, just thought id give it a shot. Link to comment Share on other sites More sharing options...
Code Posted January 4, 2012 Share Posted January 4, 2012 Are your current headers the main restriction in your exhaust right now? Probably not. If you absolutely want to upgrade them then save your money and don't buy junk that will eventually be a headache. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
JonnyWachter Posted January 4, 2012 Author Share Posted January 4, 2012 no, i wasn't even in the market for headers, i was looking for an up pipe and stumbled across this. Im in the process of going stage 2, i have a CNT DP and now need an UP and CBE. Link to comment Share on other sites More sharing options...
Code Posted January 4, 2012 Share Posted January 4, 2012 What year lgt? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
JonnyWachter Posted January 4, 2012 Author Share Posted January 4, 2012 2005 Link to comment Share on other sites More sharing options...
bmx045 Posted January 4, 2012 Share Posted January 4, 2012 just get the up pipe, headers don't do a whole lot unless your stage 3+, you'll lose a little bit of low end power but a gain a little top end due to the flow increase....a small curve shift to the right Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 4, 2012 Moderators Share Posted January 4, 2012 Not to hijack this thread, but is it common opinion that any up pipe with a flex section could be a problem or just cheap knock off crap? I keep looking at up pipes and was planning to go with a flex pipe for ease of fitment and installation, but didn't realize that this could be a potential problem... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
bmx045 Posted January 4, 2012 Share Posted January 4, 2012 I'd say a good 9/10 of them leak from there over time. If they don't leak from there, they'll crack at the welds. One or the other....take your pick Link to comment Share on other sites More sharing options...
G5892 Posted January 4, 2012 Share Posted January 4, 2012 I have a DC Sports up-pipe with a flex section. Ive had it for almost 2 years now and it hasnt given me any probelms. Link to comment Share on other sites More sharing options...
Spec B Posted January 4, 2012 Share Posted January 4, 2012 I am running a stock gutted up pipe..I hope it works with the Perrin ELH I will be installing soon. Link to comment Share on other sites More sharing options...
JonnyWachter Posted January 5, 2012 Author Share Posted January 5, 2012 i would gut mine, but i don't have any experience with doing that task and i heard its a pain. Link to comment Share on other sites More sharing options...
whitetiger Posted January 5, 2012 Share Posted January 5, 2012 just get the up pipe, headers don't do a whole lot unless your stage 3+, you'll lose a little bit of low end power but a gain a little top end due to the flow increase....a small curve shift to the right generally id agree, but a good EL header like the gt spec one which comes with a solid UP and 3-bolt header/up flange will give improvement across the rpm band if tuned properly. if you are gonna get a header, EL FTW Link to comment Share on other sites More sharing options...
