lulzcow Posted January 2, 2012 Share Posted January 2, 2012 So, I have owned my car for 7 months about. When I bought it, I replaced the pads and rotor for the front right wheel. Last month, I had to replace them again, as the rotor was warped and the pads worn to the back. It hasn't been a full month yet, and my brakes are coating the wheel in brake dust/rust. None of the other wheels are having this issue. Anyone have a clue what could be going on? The brake squeeks occasionally when used. I checked the wheel for play and don't think the wheel bearing is bad.. Link to comment Share on other sites More sharing options...
overspool Posted January 2, 2012 Share Posted January 2, 2012 Bleed your brakes, and check how well greased the sliding pin is for the FR. Link to comment Share on other sites More sharing options...
subikid90 Posted January 2, 2012 Share Posted January 2, 2012 Sounds like your caliper is frozen or sticking badly. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 3, 2012 Share Posted January 3, 2012 plus one. feel your rotors after a drive. if that one is hotter then the rest then you got sticky pots and or slides BNR18g on 93oct Link to comment Share on other sites More sharing options...
Kennyfvholla Posted January 3, 2012 Share Posted January 3, 2012 Take everything apart and grease all the metal parts that come into contact with another part. No grease can cause squeaking and hang up the pad and cause it to stick. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 3, 2012 Share Posted January 3, 2012 just dont put it on the pad or the rotor lol. if that sqeaks its not bad BNR18g on 93oct Link to comment Share on other sites More sharing options...
stevenva Posted January 3, 2012 Share Posted January 3, 2012 plus one. feel your rotors after a drive. if that one is hotter then the rest then you got sticky pots and or slides Did that once, burned my finger. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
lulzcow Posted January 3, 2012 Author Share Posted January 3, 2012 Piston in the caliper is sticking. Greasing everything up and bled the brake line. It works better for now. Will just order new calipers soon and install the stainless steel cables at the same time. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 4, 2012 Share Posted January 4, 2012 Did that once, burned my finger. i didnt say it wouldn't be hot. i said they should be the same temp.. did the other one burn just as bad? or if yall want you can buy touchless temp readers for liek 10-20 bucks. thats what i use BNR18g on 93oct Link to comment Share on other sites More sharing options...
lulzcow Posted January 4, 2012 Author Share Posted January 4, 2012 i didnt say it wouldn't be hot. i said they should be the same temp.. did the other one burn just as bad? or if yall want you can buy touchless temp readers for liek 10-20 bucks. thats what i use Wutttt? A thermometer? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 4, 2012 Share Posted January 4, 2012 no. its a surface temp reader. uses IR light BNR18g on 93oct Link to comment Share on other sites More sharing options...
stevenva Posted January 4, 2012 Share Posted January 4, 2012 "did the other one burn just as bad?" No. I realized I could just touch the alloy wheel instead. 1 wheel was warm, others weren't RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 4, 2012 Share Posted January 4, 2012 I just feel my hand over them after a hard drive when i dont have my temp reader. but when i do have the temp reader i like to see the temps within 50 degrees of each other. BNR18g on 93oct Link to comment Share on other sites More sharing options...
FJuan Posted January 5, 2012 Share Posted January 5, 2012 Had the same problem once, until I found out that one of my slide pins was frozen. The rubber sleeve came loose inside the housing and freezed the pin. Once I got it out, I took the sleeve off and reinstalled the pin. Problem solved. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
