AKpowderLGT Posted January 2, 2012 Share Posted January 2, 2012 Just tries to put LED back up lights in, one of them didn't work so i started messing with it, while I'm doing so the drivers side led goes out. I pulled both of them and put the old ones back in. BOTH DON'T WORK! This whole time I had the car in run so I could see if I had the LEDs in properly. I look up my HIDs are not on, headlights and fogs.. I have no back up lights whatsoever. And the only way for my headlights to come on is in the off position with it in reverse or the parking brake on. No fogs either! Really need help on this one please Thanks. Aaron Link to comment Share on other sites More sharing options...
Max Capacity Posted January 3, 2012 Share Posted January 3, 2012 Try here, http://legacygt.com/forums/forumdisplay.php/exterior-aesthetic-44.html There is also a member that offers kits for LED's. His on-line name is something like INVOLSOV. He should be able to help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Lardo420 Posted January 3, 2012 Share Posted January 3, 2012 did u bro a fuse? Link to comment Share on other sites More sharing options...
bmx045 Posted January 3, 2012 Share Posted January 3, 2012 clearly a fuse blew during your inherent lackluster attempt at light bulb installation. Link to comment Share on other sites More sharing options...
