smokee_won Posted April 24, 2014 Share Posted April 24, 2014 He is referring to how you bolted the back hole of the brembo two pots to the rear backing plate mount and welded a new mounting location for the forward brembo hole; resulting in the tilt of the calipers. Both holes are no longer equidistant from the center of the shafts axis. He is thinking that is causing the caliper to not sit squarely..., perpendicular to the rotation, or "off axis". Link to comment Share on other sites More sharing options...
tyty13 Posted October 31, 2018 Share Posted October 31, 2018 Dose the front brake caliper form a wrx 4 pot work? Link to comment Share on other sites More sharing options...
rhd gvr4 Posted November 3, 2018 Share Posted November 3, 2018 Thank you helped so much to get my brakes done! Link to comment Share on other sites More sharing options...
