sam6140 Posted December 23, 2011 Share Posted December 23, 2011 I would like to remove and clean mine. But, I think I located it, not quite sure. Anyone have any photos of where it is? Also, how do I get it off? Is it easy to remove? Do I need gaskets? It looked like it's in an awkward place to remove. And I know how great cars run, when you remove them and clean them and put them back in. Mine idles a little funny sometimes. And it's pretty much the last possible fix, that I haven't done. Link to comment Share on other sites More sharing options...
sam6140 Posted December 23, 2011 Author Share Posted December 23, 2011 [ame=http://www.youtube.com/watch?v=0WoQxA5q9io]How To Replace The Idle Air Control Valve On Your Older Subaru - YouTube[/ame] Just found the above link. It shows how to remove and reinstall the IACV. It actually looks like a little more work than I would like to do. My hands are kinda big, and it's a tight spot. Link to comment Share on other sites More sharing options...
sqc151 Posted December 24, 2011 Share Posted December 24, 2011 on my other suby, i loosned up the screws while the car was running. then adjust the iac till u find the sweet spot, re tighten screws. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted December 27, 2011 Share Posted December 27, 2011 Haha, that's how I did it too and most people were complaining about it. Seemed to work fine for me. Link to comment Share on other sites More sharing options...
sam6140 Posted December 28, 2011 Author Share Posted December 28, 2011 I'm confused...this thread is about re and re of the IACV, not adjusting the idle. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted December 28, 2011 Share Posted December 28, 2011 It's about adjusting it when you put it back if your idle has been weird. Either way there should be 4 or 5 bolts and a line connected to coolant on the bottom. You dont need to disconnect the electrical component from the body. You can do it the crappy way like I did my first time and shoot it out/scrub it out with carb cleaner and a brush or if you have a compressor you can buy an engine cleaning kit for $8 and spray it out with gas. Either way, if you're gonna clean it, clean it big. Get in every spot...because Subaru has a hard time finding out which gasket you're talking about when you order it. Link to comment Share on other sites More sharing options...
wokeupgrumpy Posted November 27, 2015 Share Posted November 27, 2015 So, I just brought my first Subaru home. 90 Legacy wagon with only 113K on the clock. I think this is my problem so I'm going to try it tomorrow. Will let yo know how it goes. Just found the above link. It shows how to remove and reinstall the IACV. It actually looks like a little more work than I would like to do. My hands are kinda big, and it's a tight spot. Link to comment Share on other sites More sharing options...
wokeupgrumpy Posted December 27, 2015 Share Posted December 27, 2015 Turns out the valve was already replaced. It just needed adjustment. Sent from my SAMSUNG-SM-N910A using Tapatalk Link to comment Share on other sites More sharing options...
wokeupgrumpy Posted January 3, 2016 Share Posted January 3, 2016 on my other suby, i loosned up the screws while the car was running. then adjust the iac till u find the sweet spot, re tighten screws. Try this first. Mine had already been replaced. The previous owner just didn't adjust it. Plus, I had two injectors shorting which was probably the issue previously, rather than the IAC valve. Link to comment Share on other sites More sharing options...
