DoDo1975 Posted December 19, 2011 Share Posted December 19, 2011 Anyone have any tricks to seating the fuel injector into the fuel rail? I have my new injector in, but can't get it seated nicely. It seems like the difficulty is the o-ring. It is cylinder #4 on a 2005 lgt so its a little difficult getting in there with hands, but I twisted in with a fair amount of pressure and I just can't get it to seat. Any tricks or tips? Link to comment Share on other sites More sharing options...
Turkeylord Posted December 19, 2011 Share Posted December 19, 2011 I used the butt end of a screwdiver when I did mine Friday night, but I've also read that an O2 sensor socket works well. *edit* Oh, and I also used a thin coat of motor oil on the o-rings. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 19, 2011 Share Posted December 19, 2011 I just lubed mine up a bit and pushed them on in there. No problems. Maybe your o-rings are not as compliant. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
DoDo1975 Posted December 19, 2011 Author Share Posted December 19, 2011 I used the butt end of a screwdiver when I did mine Friday night, but I've also read that an O2 sensor socket works well. *edit* Oh, and I also used a thin coat of motor oil on the o-rings. I used the injector clamp down to force them to seat properly. Wondering if the cold o-rings were just more difficult to compress. Did your car run really rough for a while after installing? Does it take the ECU a while to compensate? Link to comment Share on other sites More sharing options...
Turkeylord Posted December 20, 2011 Share Posted December 20, 2011 Mine ran great right away. Did you cycle the key a few times to prime the fuel system before cranking it over? Link to comment Share on other sites More sharing options...
DoDo1975 Posted December 20, 2011 Author Share Posted December 20, 2011 No, but after 10-15 minutes everything settled down and it is runnin nicely now. Link to comment Share on other sites More sharing options...
DoDo1975 Posted January 4, 2012 Author Share Posted January 4, 2012 Code is back and its running rough again. Lasted about 1 week. Misfire cylinder 4. Trying to determine next steps, MAF or coil pack or something else? Been reading the misfire thread but it is really convoluted and a litte scary. Link to comment Share on other sites More sharing options...
