shu Posted December 9, 2011 Share Posted December 9, 2011 I have a brand new set of Wilwoods I purchased for my WRX before I bought the LGT. I know the rotor size is smaller than stock (12" 2-piece rotor), so would it be a big mistake for me to install this kit? I just hate the thought of purchasing it and not getting a chance to use it. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 9, 2011 Share Posted December 9, 2011 Contact Mike or Jake at http://www.AZPinstalls.com one of them may have the answer. If not, you should be able to unbolt your caliper, swing it aside, and try and bolt up the new caliper. If I were you, unless you plan the road race the car or auto-X a lot, just with the OEM set up with good pads, may be slotted rotors. Put that money somewhere else. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
shu Posted December 9, 2011 Author Share Posted December 9, 2011 Thanks for the reply. If I didn't already have the kit in hand, I wouldn't consider the purchase of it. I'm 99% sure the kit will fit just fine; if Brembos will work, I don't think there's an issue with the hardware not bolting up. It's really more of a matter of installing smaller rotors on this car than it comes with stock. Seems like I might be losing some braking power by doing this? Link to comment Share on other sites More sharing options...
