Deer Killer Posted December 5, 2011 Share Posted December 5, 2011 0-5.6g floats 6-9% (would float before, but centered around 0) 5.6-10g is 1.8% (previously ~0) Past 10g is unchanged. My first though was a leak, but that idea doesn't make too much sense considering the upper ranges are OK. Leaks most at <5.6g flow??? I'm not exactly sure where the top line goes to, but if it's pulling some air in through some seal through the crankcase this may make some sense. This would also seem to not be a good sign for any seals in the crankcase. It should probably have a check valve in it? Link to comment Share on other sites More sharing options...
NSFW Posted December 6, 2011 Share Posted December 6, 2011 I bet that's just noise. Watch it for a week or three, see what happens. Link to comment Share on other sites More sharing options...
Deer Killer Posted December 6, 2011 Author Share Posted December 6, 2011 I'm sure it's not noise, I've gotten a snapshot everyday for the last ~2 months, there's been a clear change. Closed loop was also tuned with the romraider MAF tool. I drive 60+ minutes a day so I get plenty of data and learn time. I don't know if anyone else with the AOS has checked like me, I see no posts. Link to comment Share on other sites More sharing options...
Spec B Posted December 6, 2011 Share Posted December 6, 2011 Could it be the change from summer to winter blend gas? Link to comment Share on other sites More sharing options...
Deer Killer Posted December 7, 2011 Author Share Posted December 7, 2011 All ranges would move the same percentage, no? Link to comment Share on other sites More sharing options...
sumfoo1 Posted December 7, 2011 Share Posted December 7, 2011 ok after a TIP & an AOS should one re-scale their MAF? I feel like i have a vacuum leak, but i can't find it. I've double & triple checked everything. The car idles at 15.9-16.2 afr when it's set at 14.7. I'm working on getting some good logs to see if the whole thing is off or just at idle. Thanks. Link to comment Share on other sites More sharing options...
Deer Killer Posted December 7, 2011 Author Share Posted December 7, 2011 ok after a TIP & an AOS should one re-scale their MAF? I feel like i have a vacuum leak, but i can't find it. I've double & triple checked everything. The car idles at 15.9-16.2 afr when it's set at 14.7. I'm working on getting some good logs to see if the whole thing is off or just at idle. Thanks. What's a TIP? No, theoretically one should not have to rescale the MAF. If everyone see's a problem then there is a potential issues with the AOS - my guess is probably needs a check valve in the return line. If anyone else has before/after AF learning snapshots, it would be helpful. Link to comment Share on other sites More sharing options...
sumfoo1 Posted December 7, 2011 Share Posted December 7, 2011 Turbo inlet pipe. Link to comment Share on other sites More sharing options...
bmx045 Posted December 7, 2011 Share Posted December 7, 2011 shouldn't need to, no. your A/F adjustment is indicative of a vac leak Link to comment Share on other sites More sharing options...
Th3Franz Posted December 10, 2011 Share Posted December 10, 2011 Did you clamp all your breather hoses and the hoses connected to the inlet? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Leonardo Posted December 12, 2011 Share Posted December 12, 2011 Updates? Link to comment Share on other sites More sharing options...
sumfoo1 Posted December 12, 2011 Share Posted December 12, 2011 Cracked intecooler.... Link to comment Share on other sites More sharing options...
Deer Killer Posted December 12, 2011 Author Share Posted December 12, 2011 Updates? Values are still stable where last reported. Checked for leaks, couldn't find any. Although like I said, a leak would open up more at high flow, which means that ranges A-D should all be affected. Hard to imagine any of those hoses leaking considering the force required to put them on :/ Maybe I fixed a leak with the install? LOL. Although unfortunately there still appears to be some oil consumption where I expected 0. Searched for other people's oil consumption reports, found none trustworthy. Have the measure and check more precisely over the next 1000 miles. Link to comment Share on other sites More sharing options...
