severedevil Posted December 3, 2011 Share Posted December 3, 2011 so think it would be better to replace my valves or buy these off ebay? http://www.ebay.com/itm/130590570941?ssPageName=STRK:MEBOFFX:IT&_trksid=p3984.m1427.l2649 Valves are about $140 to replace all + Taxes. +time and machining the valve seats on the head. smarter to replace or scrap and get these from ebay? Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 3, 2011 Share Posted December 3, 2011 I think you know what you want to do... Link to comment Share on other sites More sharing options...
LuckyBob Posted December 3, 2011 Share Posted December 3, 2011 You can fairly easily mate the new valves to your existing head by hand with a power drill and a some lapping compound. Running in ChumpCar teaches you these things Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 3, 2011 I Donated Share Posted December 3, 2011 The ebay head comes with a red valve cover....for racing -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
severedevil Posted December 3, 2011 Author Share Posted December 3, 2011 well in the description the guy says it has HLA lifters(hydraulic lifters) which idk what they are but he says there good... lol Link to comment Share on other sites More sharing options...
MikeSomething Posted December 3, 2011 Share Posted December 3, 2011 For the price... grab the head also... Link to comment Share on other sites More sharing options...
johnegg Posted December 3, 2011 Share Posted December 3, 2011 HLAs are hydraulic lash adjusters. oil pressure is used to fil small hydraulic cylinders on each valve rocker. as long as they are working correctly you never need to adjust the valves. these were common on 90 - 96 ej22s and i think they were only on the 96 ej25, and maybe not all of those. they went to bucket and shim adjusters in 97 on the ej25. HLAs are much more user friendly but i think bucket and shim or standard threaded adjuster w/ lock nut are more HP friendly. but i'm not really sure. Link to comment Share on other sites More sharing options...
sense of nature Posted December 3, 2011 Share Posted December 3, 2011 Replace valves .. cheaper imo Link to comment Share on other sites More sharing options...
severedevil Posted December 4, 2011 Author Share Posted December 4, 2011 ok i pulled the heads off today. the intake valves on both sides are bent. theres about 1/16th of an inch gap completely visible on all 8 intake valves. now the exhaust look good to the eye but havnt tried putting kerosene in to test yet. could this have caused any damage to the piston heads? should i be worried and replace them as well or should they be ok? i will test the valves tomorrow with kerosene in them to see if the exhaust valves leak and maybe take a picture. johnegg - "HLAs are much more user friendly but i think bucket and shim or standard threaded adjuster w/ lock nut are more HP friendly" could you let me know which is more hp friendly? and if mines a 97 would they work? eBay says it would but i don't trust eBay judgement. Link to comment Share on other sites More sharing options...
johnegg Posted December 4, 2011 Share Posted December 4, 2011 look for a car or engine with bad head gaskets that has been cooked, or overheated . folks who do ej22 swaps or even swapping in a newer ej25 will sell the engine for less then 200$. or just buy heads from www.car-part.com . heads are $100 each plus shipping, if needed. i don't think your 97 has HLAs so i don think the head in the ebay ad will work unless you get two of them. 96 was the first year for the ej25. in 97 they tweaked it and squeezed out a little more HP. one of the tweaks was no more HLAs. (also, 96 needed premium gas, 97+ only needs regular.) Link to comment Share on other sites More sharing options...
Kennyfvholla Posted December 4, 2011 Share Posted December 4, 2011 Your 97 doesn't have HLA lifters Shimmed bucket lifters are more horsepower friendly in the higher rpms. If you're not planning on building an engine with over 300 crank horsepower you would be fine with HLA's. The Impreza 22B had HLA heads, made 280HP, and revved to 7500 rpm. However, I do not know if the HLA's would fit in the later 97 to 99 cylinder heads, but I would think that they should no problem. Link to comment Share on other sites More sharing options...
