19Legacy97 Posted November 29, 2011 Share Posted November 29, 2011 Turns out my leggy has two lobes on the crank that are gone. Mechanic says i need a new engine. is he bs-ing me? Or do i need a new engine? Link to comment Share on other sites More sharing options...
Toallhisdoom Posted November 29, 2011 Share Posted November 29, 2011 Swap time! Link to comment Share on other sites More sharing options...
subikid90 Posted November 29, 2011 Share Posted November 29, 2011 You need a rebuild or a new motor. Rebuild will be more reliable and last longer if done right, but swapping a used motor in will be much cheaper. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
19Legacy97 Posted November 29, 2011 Author Share Posted November 29, 2011 So, i found a EJ20 twin turbo with a 5spd. says 93-98 impreza. Would it fit? (I know im going to have to deal with that one side) due to the turbo. would it like bolt up and plug in all nice? If it will :spin: Oh and the target car has an auto. Soo i will have to do some fixing. Anything i'll need to know/buy? My mechanic said if i can find him a motor he'll swap it in. Link to comment Share on other sites More sharing options...
subikid90 Posted November 30, 2011 Share Posted November 30, 2011 Anything that is not the original motor will require a lot of wiring. Brain at IWire will merge the harness for you for $600, then the rest is a cake walk. Single turbo conversion will require some work but there are DIY on how to do it. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 30, 2011 I Donated Share Posted November 30, 2011 read the freaking engine faq -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
19Legacy97 Posted December 1, 2011 Author Share Posted December 1, 2011 Yeah i read it, Financially the TT motor is out of the question... for now. I got my self a nudder 2.5 with 125,00kms So all should be well soon. I shouldn't have to worry about the head gasket should i? thanks for help. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 1, 2011 I Donated Share Posted December 1, 2011 Yes you should have to worry about the head gaskets -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Frogg Posted December 1, 2011 Share Posted December 1, 2011 before u put it in, redo all the gaskets Link to comment Share on other sites More sharing options...
mtcookson Posted December 1, 2011 Share Posted December 1, 2011 ALL of them, including the seals. Front and rear main, cam seals, valve cover gaskets, any preventative maintenance you can do while the engine is out while absolutely everything is accessible is always a good thing. Just less work you have to do down the road when the engine is in the car. I would also do the timing belt, water pump, thermostat, and I would check all of the timing belt pulleys to ensure they are good. Most likely you'll need/want to replace those as well. The pulleys in my 300k mile engine were bone dry and even the 130k mile pulleys in my friend's WRX were pretty dry as well. Definitely wouldn't hurt. Like I said, preventative maintenance. You'll be happy you did. Link to comment Share on other sites More sharing options...
subikid90 Posted December 1, 2011 Share Posted December 1, 2011 DO NOT forget the oil separator plate behind the flywheel. Search and you will find out how to fix the issue -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Toallhisdoom Posted December 1, 2011 Share Posted December 1, 2011 why say "Search and you will find out how to fix the issue" when in less words you can just say "if its plastic, replace it" lol! newb Link to comment Share on other sites More sharing options...
subikid90 Posted December 1, 2011 Share Posted December 1, 2011 ^Because that doesnt cover it all. Where is it at? How do you replace it? What do you torque it too? What do you use to seal it? Where do you get the part? Why do you replace it? Do you get my drift yet? lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
mtcookson Posted December 1, 2011 Share Posted December 1, 2011 Where is it at? How do you replace it? What do you torque it too? What do you use to seal it? Where do you get the part? Why do you replace it? Hmm... I'll take a crack at it: Behind the flywheel. Unscrew/unbolt screws/bolts. Torque it till it breaks, back off 1/4 turn. Elmer's. Subaru/Junkyard. Because you said so. I'm sorry... i'm booooooored right now. 19 minutes before I get off work and install the short throw in the Legacy. Link to comment Share on other sites More sharing options...
19Legacy97 Posted December 2, 2011 Author Share Posted December 2, 2011 ^^ nice. i remembered something, About a month ago i was under my car trying to find where the damn oil leak was coming from and i noticed my rear cat had a nice dent in it... Makes me wonder why i'm throwing o2 codes. would i be able to remove said cat? Link to comment Share on other sites More sharing options...
johnegg Posted December 3, 2011 Share Posted December 3, 2011 what two lobes on the crank?????? i realize the conversation has moved on to other more interesting subjects, but i was just curious what lobes you were talking about. Link to comment Share on other sites More sharing options...
