Baddog Posted November 28, 2011 Share Posted November 28, 2011 As we all know he was rally crossing in the back roads and hit a deer. Please post all your problems here instead of starting 50 new threads. Thanks AMORGAN Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 29, 2011 Share Posted November 29, 2011 i thought i about doing this. all problems solved no though. i was was gonna put it all in my build thread. but i started the deer meets swagon. how do you you detach the PS tank from the pump? i cant find a complete new pump on rockauto. BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 29, 2011 Share Posted November 29, 2011 http://www.ebay.com/itm/JDM-SUBARU-LEGACY-BD-BG-RED-EMBLEM-TURBO-FRONT-GRILL-OEM-/260897428566?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3cbeb2d456#ht_1173wt_980 some one buy this or i will. damn it. BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 29, 2011 I Donated Share Posted November 29, 2011 wait..... swagon = amorgan??? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 29, 2011 Share Posted November 29, 2011 That grill is too small for your opening broseph. It's made for the small openings. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted November 29, 2011 Share Posted November 29, 2011 i dont get it. i see this thread turning into super wide. damn... BNR18g on 93oct Link to comment Share on other sites More sharing options...
jamaha51 Posted November 29, 2011 Share Posted November 29, 2011 Shwagon, you just does that to threads! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted December 1, 2011 Share Posted December 1, 2011 my car is getting ruff. tranny wise and and front hub. i puting a list of parts together to smooth the ride out and tighten things. add as you like new lower ball joints tranny mount engine mounts rotors pads atf drain and refill steering rack bushings. add as you like BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted December 1, 2011 Share Posted December 1, 2011 ^Why are you just buying parts when you dont know the issue? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted December 2, 2011 Share Posted December 2, 2011 i know those are all bad BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted December 8, 2011 Share Posted December 8, 2011 can some one help me wire up my new radiator fans? subaru has 3 wires coming out of the cars harness. ones black and the other two color. the black splits into 2 before it get to the fans. i had a volt meter hooked up to it and never got a single reading. but yet when i plug the old broken fans in they work. btw. in order for this thread to work you guys actually need to use it like i just have. otherwise ill start a new topic... again. with the correct title BNR18g on 93oct Link to comment Share on other sites More sharing options...
eekay Posted December 10, 2011 Share Posted December 10, 2011 You had a multi-meter on each wire and grounded it? No reading on any wires? You're doing it wrong. There should be voltage from something. I can't give you an exact answer as far as wiring yet (car is still doing ECU/exhaust upgrade) but I can give you specs on the volts if you haven't figured it out yet. Then again, maybe I don't understand what you're getting at? My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted December 11, 2011 Share Posted December 11, 2011 i got 2 wire fans and a car with 3 wires. idk what to hook up. BNR18g on 93oct Link to comment Share on other sites More sharing options...
eekay Posted December 11, 2011 Share Posted December 11, 2011 What color are the wires for the fans? Are both fans requiring a 3-wire setup? 2-wire fans generally require a ground and a positive. When the positive sends power, the fan comes on. However, a 3-wire fan may always have a ground, positive and a on/off (possibly due to temp?) relay. If the fans only have two wires and the car requires 3, you may be b0rk3d. I say MAY because there is ALWAYS a workaround. I'm just not quite sure what it is. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
SpecBamf41 Posted December 11, 2011 Share Posted December 11, 2011 maybe a relay of some sort. BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted December 13, 2011 Share Posted December 13, 2011 are these spark plugs good in our cars? my car sputters bad when you first punch in from idle. BNR18g on 93oct Link to comment Share on other sites More sharing options...
lulzcow Posted December 13, 2011 Share Posted December 13, 2011 Idk which spark plugs you're referring to, but I hear NGK is the way to go and Bosch is a no no Link to comment Share on other sites More sharing options...
eekay Posted December 13, 2011 Share Posted December 13, 2011 +1 on the NGK's. It's all I use. I have used Bosch in the past and I didn't have any problems. I certainly feel the difference with the NGK's though. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
lulzcow Posted December 13, 2011 Share Posted December 13, 2011 I'm going to have to FINALLY install the NGK Laser Iridiums I have sitting in my glovebox this weekend. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted December 13, 2011 Share Posted December 13, 2011 nice.. hope fully this helps my stutter problem BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted December 13, 2011 Share Posted December 13, 2011 what size bulb is used for the highs in the jdm headlights BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted December 13, 2011 Share Posted December 13, 2011 ^H3 i believe -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
eekay Posted December 13, 2011 Share Posted December 13, 2011 Yup. H3's. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
Kennyfvholla Posted December 13, 2011 Share Posted December 13, 2011 What about the low beam? I don't remember for sure, but I think they're H1's right? Link to comment Share on other sites More sharing options...
subikid90 Posted December 13, 2011 Share Posted December 13, 2011 Yep H1's -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
