HDTurbo Posted November 24, 2011 Share Posted November 24, 2011 am i missing this parameter? Is it not a feature? Link to comment Share on other sites More sharing options...
goneskiian Posted November 24, 2011 Share Posted November 24, 2011 Doesn't look like it... http://www.cobbtuning.com/info/?ID=4418 Hmmm, I thought there were more parameters as well. Aren't there some knock associated parameters not on that list? Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted November 24, 2011 Share Posted November 24, 2011 Here's the latest expanded monitor list, but oil pressure is not one of them. http://www.accessecu.com/support/docs/Subaru%20AccessPORT%20-%20Firmware%201.6.4.0%20-%20Monitor%20Updates%20and%20Definitions%20Guide.pdf The LGT only has a 2 psi Replace Engine Idiot Light. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted November 26, 2011 Share Posted November 26, 2011 ^^Yep The LGT oil pressure sensor is just a switch. On or off. Do you have oil pressure? Yes/no. Link to comment Share on other sites More sharing options...
Deer Killer Posted November 28, 2011 Share Posted November 28, 2011 There is no oil pressure sender on the car. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted November 29, 2011 Share Posted November 29, 2011 There is an oil pressure switch. Didn't think that I needed to be so technical. Link to comment Share on other sites More sharing options...
HDTurbo Posted November 29, 2011 Author Share Posted November 29, 2011 There is an oil pressure switch. Didn't think that I needed to be so technical. and neither did Cobb here's hoping the bulb in my little red 'genie' lamp doesn't burn out Link to comment Share on other sites More sharing options...
