Pocono Legacy GT Posted November 20, 2011 Share Posted November 20, 2011 Just drove on the highway at about 70-80 mph steady and when I got off and stopped at a red light my idle lowered to about 300 rpms and then stalled. When I re-started it, check engine light and cruise are now blinking. Scanned with my Tactrix: (P1518 Starter Switch Low Input), (P1152 Front o2 Sensor Range/Perf Low B1 S1), (P1153 Front o2 Sensor Range/Perf High B1 S1), and (P0700 Transmission Control System). Please help! Stage II, turbo-back exhaust, Cobb SF intake. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 22, 2011 Share Posted November 22, 2011 I would replace the front O2 sensor, I got mine from advance auto parts, I think, I can't remember now. Oh may be it was a local Car Quest auto parts. I seem to recall there was a problem getting them... I also replace my rear O2. Then start the car after you clear the codes and see what's up I'm guessing the other 2 codes were because of the bad O2 causing low idle. FWIW, I also cleaned the MAF and IAT senosrs with a dry Q-tip. My 05 run's much better now then before I did all that. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted November 22, 2011 Share Posted November 22, 2011 PM this guy, see what he did, wlam3 Title: Junior Member Posts: 40 iTrader: (0) These are all the codes I have p0700 Transmission Control System Malfunction P1152 - Front O2 Sensor Circuit Range/Performance (Low) P1153 - Front O2 Sensor Circuit Range/Performance (High) P1518 - Starter Switch Circuit Low Input I found that post in the next thread down on the this forum currently. it's post 91 in c-lo thread 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Pocono Legacy GT Posted November 29, 2011 Author Share Posted November 29, 2011 So. I went to the gas station and filled up my tank (with Supreme of course), and started the subie back up and the CEL is off and cruise stop blinking. I think my subie threw all those codes just because my gas cap wasn't tighten on correctly. Link to comment Share on other sites More sharing options...
