Lardo420 Posted November 16, 2011 Share Posted November 16, 2011 as the title states, I need help with the walbro install in the stock fuel pump housing. I followed the walbro install thread on here, as well as this one http://www.iwsti.com/forums/how-install/152257-walbro-255lph-pump-2008-sti-wrx-lgt.html but for some reason it doesnt want to fit together very well. If you look at this picture I feel like the pump is bottomed out too much. Also, the clips are extremely hard to clip and i feel like i am going to break the housing. Any advise? Link to comment Share on other sites More sharing options...
mustangendsley Posted November 16, 2011 Share Posted November 16, 2011 you might have shaved to much off the housing. Link to comment Share on other sites More sharing options...
Lardo420 Posted November 16, 2011 Author Share Posted November 16, 2011 wouldnt that mean it would fit too far up and be the opposite of what is going on Link to comment Share on other sites More sharing options...
Lardo420 Posted November 17, 2011 Author Share Posted November 17, 2011 anyone? Link to comment Share on other sites More sharing options...
itsme Posted November 18, 2011 Share Posted November 18, 2011 You have to cut the tabs in the housing and grind down the round tabs on the pump to make the pump fit all the way into the housing. This thread pretty much covers it. http://legacygt.com/forums/showthread.php/walbro-fuel-pump-install-127809.html?t=127809&highlight=pump+install Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
itsme Posted November 18, 2011 Share Posted November 18, 2011 But, it does fit tight and did you uses the proper o-ring? Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Lardo420 Posted November 18, 2011 Author Share Posted November 18, 2011 I followed all of those steps, and yes it fits tight, but the pump seems to bottom out on the housing and its nearly impossible to get all the clamps to become set. Is there any difference in dimension between the 255 and the 342? Link to comment Share on other sites More sharing options...
.blackgt. Posted November 18, 2011 Share Posted November 18, 2011 The way you have it will work. You did not shave off "too much" of the housing, since that would give you more clearance. Don't shave off too much or it will come apart. If I could take a pic of mine, you would see that it is actually touching the bottom of the housing just like yours. As long as you can get the clips together, you are fine. Link to comment Share on other sites More sharing options...
itsme Posted November 18, 2011 Share Posted November 18, 2011 Are talking at the model number gss342? It's tight and hard to put togther. That's how it fits. That is why DW is coming out with a true drop in to fix the problem. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Lardo420 Posted November 18, 2011 Author Share Posted November 18, 2011 yes itsme, model number gss342. is that just the model number for the 255? Link to comment Share on other sites More sharing options...
itsme Posted November 18, 2011 Share Posted November 18, 2011 yes itsme, model number gss342. is that just the model number for the 255? If you grinded the tabs on the pump properly it is still a tight fit. I would say put it in you should be fine. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Lardo420 Posted November 18, 2011 Author Share Posted November 18, 2011 i ended up putting the stock one in just so i could finally start my car, i am going to drop it off at a local subie shop and just have them do it cuz i dont want to break the housing. Link to comment Share on other sites More sharing options...
itsme Posted November 18, 2011 Share Posted November 18, 2011 Wait I looked at your picture again. Can you pull your pump and let me see how much you grinded down the round tabs on your walbro pump. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Lardo420 Posted November 18, 2011 Author Share Posted November 18, 2011 it looks identical to the picture in that link on here and on iwsti Link to comment Share on other sites More sharing options...
itsme Posted November 18, 2011 Share Posted November 18, 2011 If it is like that then you should be OK. I have done about 20 pump installs and they all were tight. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
