mtcookson Posted November 10, 2011 Share Posted November 10, 2011 Ok, have a few different issues. The speedometer doesn't work, which seems to be a pretty common issue. I'm not too concerned about that right now as I have GPS, however I did pull it out and look around in it to see if I could find any issues. Someone had already pulled it and tried the screw-in-the-blue-plastic-connector trick seemingly without success. I checked for continuity everywhere and couldn't find any open connections, checked the diodes and resistors and everything checked out. Must either be the chips, wiring, or speed sensor. Will likely try a new cluster before long as that seems to be the trick. My real question is on the tach though. Haven't been able to find anything on this issue. The tach is extremely sluggish. I'm talking like it would probably take somewhere around 20 seconds or maybe even much more for it to read the proper RPM. The only possible reason I can think of for this occurring is because I put an Impreza engine in there (1997 2.2) but... I really doubt it. I didn't notice any differences while looking them over. I could definitely be wrong though as I'm brand new to Subaru's. Anyone experience this before or have any ideas that I could try to get this thing working? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 10, 2011 I Donated Share Posted November 10, 2011 Check your crankshaft position sensor. That would explain the poor response from the tach. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
mtcookson Posted November 10, 2011 Author Share Posted November 10, 2011 Just figured it out... I should have checked the needle. Thought I did but definitely did not. Needle was difficult to move, something wrong inside the motor from what I can tell. Fortunately had an extra cluster that I bought for the Impreza, swapped some stuff around, and have it working again. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 10, 2011 I Donated Share Posted November 10, 2011 congrats -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
mtcookson Posted November 10, 2011 Author Share Posted November 10, 2011 Thanks. Hopefully I can make the speedo work somehow now lol. First things first... have a nasty oil leak at the valve cover I need too fix. Yay... Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 10, 2011 I Donated Share Posted November 10, 2011 They arent too bad to do -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
monkeyposeur Posted November 10, 2011 Share Posted November 10, 2011 Hey brok, do you need to drain the oil to do the valve cover gaskets? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 10, 2011 I Donated Share Posted November 10, 2011 No. You might need to top it off just a hair after your done though....but likely not -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
mtcookson Posted November 10, 2011 Author Share Posted November 10, 2011 They arent too bad to do Yeah, just finished. Permatex The Right Stuff... best gasket maker/sealer ever lol. Should keep it sealed for quite a while, at least until I can get new gaskets. If you give it a bit to drain you should have next to no oil come out when you remove the valve cover. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 10, 2011 I Donated Share Posted November 10, 2011 Mr. Speedy! -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
DrakeMK3 Posted November 11, 2011 Share Posted November 11, 2011 I had similar trouble with the speedometer on my wife's 99 outback. I tried the screw method at first and it worked for a couple days, then quit. So, I took the cluster back out, removed the screw from the plastic connector and fixed it the right way by soldering a small piece of wire from/to the solder joints on the board bypassing the imprinted circuitry. That has fixed the problem for the last 7k miles. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 12, 2011 I Donated Share Posted November 12, 2011 Yeah...its the blue wire http://i249.photobucket.com/albums/gg240/johnceggleston/m86025_dscn2765.jpg -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
mtcookson Posted November 15, 2011 Author Share Posted November 15, 2011 Yeah, I saw that fix on here. I tested continuity between those points and didn't see any problems but perhaps I should try that fix anyway. Absolutely hate the 4.2k rev limit when the speedometer doesn't work. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 15, 2011 Share Posted November 15, 2011 Yeah, just finished. Permatex The Right Stuff... best gasket maker/sealer ever lol. Should keep it sealed for quite a while, at least until I can get new gaskets. Aviation Permatex is even better. I used it all over the place when I did my head gaskets. Link to comment Share on other sites More sharing options...
Jab83 Posted November 16, 2011 Share Posted November 16, 2011 OK. anyone have anyidea if i can get a new tech that will be able to show me the rev limit for when i do my H6 swap. I know the EG3.3 is a way higher reving engine. @_@ i've no clue what to do for that. Didn't wanna start new thread so sorry for thread jack. Link to comment Share on other sites More sharing options...
bushey45 Posted November 16, 2011 Share Posted November 16, 2011 Doesn't the eg33 rev limit at 6500? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 16, 2011 I Donated Share Posted November 16, 2011 No way to really get another tach unless you had an aftermarket one that was separate from your gauge cluster. You know the big ricey ones wiht the shift light? lol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted November 16, 2011 Share Posted November 16, 2011 Damn it. I don't think so bushy.. I think its more like 9 but I could be wrong.... Sent from my DROID X2 using Tapatalk Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 16, 2011 I Donated Share Posted November 16, 2011 I highly doubt its 9k. I can imagine 7500...but not 9k. Especially with the design of those heads. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
mtcookson Posted November 16, 2011 Author Share Posted November 16, 2011 Looks like 6500 - http://www.ebay.com/itm/1992-Subaru-SVX-Gauge-Cluster-/220839405545?hash=item336b0de7e9&item=220839405545&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr You could probably get an SVX gauge cluster and just swap the board to your current cluster so that it reads the 6 cylinder signal properly. Not positive, but it might work. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted November 16, 2011 Share Posted November 16, 2011 No way to really get another tach unless you had an aftermarket one that was separate from your gauge cluster. You know the big ricey ones wiht the shift light? lol They're not ricey in a muscle car! Link to comment Share on other sites More sharing options...
Jab83 Posted November 16, 2011 Share Posted November 16, 2011 bleh. OK. I may try that. I probably need to swap the back part anyways. it sounds like it revs sooo much higher though!!!! Link to comment Share on other sites More sharing options...
subikid90 Posted November 16, 2011 Share Posted November 16, 2011 Try swapping a cluster from and 3rd gen H6 outback -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Jab83 Posted November 16, 2011 Share Posted November 16, 2011 thats a idea!!!! Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 17, 2011 I Donated Share Posted November 17, 2011 Try swapping a cluster from and 3rd gen H6 outback I've tried wiring in clusters from different generations...its umm....difficult to say the least. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
