bmx045 Posted November 16, 2011 Share Posted November 16, 2011 looks good, how many miles do you have on the new block? Of course it depends who you ask as everyone has a different opinion. I'm pretty deadset on 1500 miles of non-synthetic oil break in, then synthetic and tune. Link to comment Share on other sites More sharing options...
sachilles Posted November 16, 2011 Author Share Posted November 16, 2011 I have 1500 plus the person who put the motor back together put a minimum of one tank of gas through, so that is another ~300 miles. It'll have 2000 on the motor by this weekend. I'll do an oil change this weekend as well. Link to comment Share on other sites More sharing options...
sachilles Posted November 26, 2011 Author Share Posted November 26, 2011 More LV's. I've been reading on the various sites. NSFW has a good learning view how to, on romraiders forums. Below I have the most recent learning view. Seeing knock in the 4000-4800 range. According to the tutorial, 1.4 is a concern, and higher is a bigger concern. I have not reset the ecu for a couple of weeks. My last posted lv, did not show this knock(at I've not reset the ecu since before the last lv post). Honestly haven't been in that rpm range all that often. Also reading up on vacuum leaks that, if you see a number closer to 14 in the air fuel learning, then you have a vacuum leak. Being at 6.3, is that a concern since the last lv was 4.8? Since I tend to be a hands on learner. I figured I'd try learning view on my 02 wrx wagon. That is attached. The max iam number is 16 with those I've learned. Can I assume other values should be similar to the norms for a legacy? This car has utec, catless uppipe, and tbe. For giggles I tried to make a copy of it's rom(Ecuflash), and was unable, despite having the green connectors connected and the jumper jumped. Wasn't sure if the utec can cause complications with that. Being a piggy back system, it just overides at a certain rpm. Can the LV still provide useful info in that case?(ie is the ecu being fooled into thinking everything is ok). If I attempt to log with romraider, will it provide useful info? or will the utec muck up the works. Link to comment Share on other sites More sharing options...
sachilles Posted November 26, 2011 Author Share Posted November 26, 2011 sorry, didn't attach previously Link to comment Share on other sites More sharing options...
NSFW Posted November 26, 2011 Share Posted November 26, 2011 It's normal for AF Learning values to move around a bit, so 6.3 & 4.8 are no big deal. They're both a long way from a vacuum leak. Other than the trouble codes, the WRX looks fine. The -2.8 in the lowest-load column is suspicious. The stock tune runs a lot of timing in that area (low load, higher-than-cruise RPM), and I've found that capping the total timing at 38 degrees leaves me with less knock. I don't know why EcuFlash can't read from your WRX, I've never worked with one. I haven't used a UTEC, but it's my understanding that you can still log the factory sensors, you just have to keep in mind that the ECU's timing, WGDC, and fueling can all be overridden by the UTEC. The UTEC has its own data logging, though I don't know whether or not RomRaider supports it. Link to comment Share on other sites More sharing options...
sachilles Posted March 22, 2012 Author Share Posted March 22, 2012 So after a tune, this is my current LV. It's about a tank and a half of gas, since the tune ~400 miles. Drives well. Subjectively feels smoother with more power. Fuel mileage seems improved as well. Is the -2.80 a cause for concern at the 4000-4800 range? Link to comment Share on other sites More sharing options...
bmx045 Posted March 22, 2012 Share Posted March 22, 2012 yes. that is concerning. its knocking two times at that load/rpm Link to comment Share on other sites More sharing options...
iNVAR Posted March 22, 2012 Share Posted March 22, 2012 Agreed. Best to log and try to catch the knock to determine what may be the cause and make changes if necessary. Who did your tune? Perhaps contact that person. Link to comment Share on other sites More sharing options...
sachilles Posted March 22, 2012 Author Share Posted March 22, 2012 OK, thanks. I'll touch base with the person who tuned it, I'm sure he'll take care of it. Just wanted to confirm that the number is warning sign. As always, thank you! Link to comment Share on other sites More sharing options...
