bmx045 Posted January 28, 2012 Share Posted January 28, 2012 you have a boost leak, check all tmic hose clamps, make sure you reinstalled the tmic properly and that the tb hose isn't folded on itself Link to comment Share on other sites More sharing options...
goneskiian Posted January 28, 2012 Share Posted January 28, 2012 What he said. It's a leak somewhere. What gaskets did you use? Link to comment Share on other sites More sharing options...
ovr9000 Posted January 28, 2012 Share Posted January 28, 2012 Thanks for the help with this, my dad and I were ready scratching our heads with this one. I know what we'll be doing tomorrow. We used the Subaru OEM gaskets all the way around. I considered the thicker grimmspeed ones, but the up pipe came with the necessary gaskets. Link to comment Share on other sites More sharing options...
bmx045 Posted January 28, 2012 Share Posted January 28, 2012 Noises like that are more commonly boost leaks rather than exhaust leaks. Boost leaks are easier to fix. Work your way back from the turbo to the intake manifold. Its easy for someone to screw up the intercooler throttle body hose, the hose is 3 pieces and often fold and crimp when shoving a tmic on Link to comment Share on other sites More sharing options...
ovr9000 Posted January 28, 2012 Share Posted January 28, 2012 is there a spot that's more likely to leak over another? I ask only because we didn't take the ic off during the install Link to comment Share on other sites More sharing options...
bmx045 Posted January 29, 2012 Share Posted January 29, 2012 Check and make sure your bpv is tight and the recirc hose clamp is tight, the throttle body hose clamps are sometimes loose and stock psi may not cause a whistle....but >14psi could. Link to comment Share on other sites More sharing options...
Levish Posted February 1, 2012 Share Posted February 1, 2012 is there a spot that's more likely to leak over another? I ask only because we didn't take the ic off during the install could be the TMIC itself leaking, i recall more than a few members had the end caps loosening. Link to comment Share on other sites More sharing options...
ovr9000 Posted February 2, 2012 Share Posted February 2, 2012 It was the throttle body, tightened it up a little bit and it leaked a lot less. Tightened it up a bit more and I heard a crack... here's hoping it's just the hose clamp. Or we'll just be getting a new ic sooner than planned Link to comment Share on other sites More sharing options...
bmx045 Posted February 2, 2012 Share Posted February 2, 2012 You probably skipped a tooth on the gear clamp Link to comment Share on other sites More sharing options...
Bonafide P Posted February 19, 2012 Author Share Posted February 19, 2012 Update on my stage 2... Loving the car, it's a whole new beast! Can't wait for a Protuned by Bren coming soon. Just to run smoother. Link to comment Share on other sites More sharing options...
