Stasis Posted November 1, 2011 Share Posted November 1, 2011 Which is driving me insane It's coming from around the rear left strut area, I thought it was where the seat clipped back at first so left it down and sound still continues :/ I've tried shaking the wheel to see if it was loose in any way but nothing. Top of the strut is done up nice and tight. 98 GTB wagon I've recorded the sound here, youtube wouldn't accept the file so chucked it on soundcloud: http://soundcloud.com/codex-1/creaking-sound you may have to turn up sound to hear it. The sounds happens when taking off and releasing clutch slowly (shudders a little when cold, may be clutch that needs adjustment but that's a different thing all together lol) Hoping someone knows -_- Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted November 1, 2011 I Donated Share Posted November 1, 2011 You can't adjust the clutch. Get a prybar and pry on the control arm. See if it has more give then the other side does. You could have bad bushings somewhere. How old are the struts? I've seen old struts make weird sounds before. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Stasis Posted November 2, 2011 Author Share Posted November 2, 2011 Struts aren't very old as far as I know, will have to check cert plate. Damn about the clutch, no biggie though. Probably is bad bushings, will work it out and see how it goes. Driving me mental lol Link to comment Share on other sites More sharing options...
Stasis Posted November 26, 2011 Author Share Posted November 26, 2011 hahaha well... while investigating this further I accidentally kneed my bumper and it made a very loud creak, moments later I checked it and the bolt on the bracket was VERY loose and a prong on the fork was bent, bent it back and bolted up tight and MUCH BETTER :D http://iforce.co.nz/i/eobyiysh.uqg.jpg This is what happens when you go in with a pre meditated idea that is completely wrong >_< Link to comment Share on other sites More sharing options...
