Theride Posted October 25, 2011 Share Posted October 25, 2011 When you shake the axle, should there be any play as if something needs tightening? I know that both ends of the axle locks in with the some "teeth" which give it that grab, but When I go and shake it, it feels like something is loose. I am asking because I am trying to track this "loose" feel I am getting pretty much when the cars gears down. And no, my endlinks are brand new. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 25, 2011 Share Posted October 25, 2011 A little movement is ok. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
