DirtyDan Posted October 25, 2011 Share Posted October 25, 2011 I don't quite understand how our TPMS works. I got a suggestion from some rock crawler friends on how truck guys get around the idiot light, but I don't know if it would work on our cars. The truck guys take all their sensors and put them inside a piece of pvc pipe, drill a hole in one end and stick a valve stem in, then seal all the sensors inside. Using the valve stem, pressurize the container and toss the thing under the seat. That way the sensors never know when they let the air down for rock crawling or sand. I know when my car dash light came on, just airing the tire up didn't turn it off until I started driving. So my question is: Is there a centrifugal detector in the sensor that turns it on or is the control unit finding the signal? Anybody know? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted October 25, 2011 Share Posted October 25, 2011 Yes, the sensors need to spin to be be activated. Search the wheels/tires section if you want detailed info as this has been covered many times. Link to comment Share on other sites More sharing options...
DirtyDan Posted October 26, 2011 Author Share Posted October 26, 2011 I did do a search, but not in tires and wheels. Oh well, I thought that was how they worked. Too bad, it sure would make things easier for 2 sets of wheels. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 26, 2011 Share Posted October 26, 2011 Great search function we have here. http://legacygt.com/forums/showthread.php/deleting-tpm-system-172243.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
