travgag Posted October 24, 2011 Share Posted October 24, 2011 Hey guys, I had posted about a 97 legacy outback i bought with the blown tranny so i found a wrecker with a 96 2.5 l with the 4eat, his books say that i wont match, the code of the tranny says tz102z2cba and mine is aba, im thinking it should fit, but dont wanna find out after i buy it thanks ! Link to comment Share on other sites More sharing options...
johnegg Posted October 24, 2011 Share Posted October 24, 2011 it will fit. absolutely the same trans. swap it in. good luck. Link to comment Share on other sites More sharing options...
travgag Posted October 24, 2011 Author Share Posted October 24, 2011 thanks alot man, your great with this stuff ! Link to comment Share on other sites More sharing options...
travgag Posted October 24, 2011 Author Share Posted October 24, 2011 any tips on how to get it out ? i have to drop the exhaust and the bolts look super rusted, i dont wanna break them off or i wont get it back on, i think ill warm it up and slap some penetrating oil and hope for the best, what about the sub frame ? do i have to remove that too ? Link to comment Share on other sites More sharing options...
travgag Posted October 24, 2011 Author Share Posted October 24, 2011 got the exhaust off ! now to the cv's, how do I get those buggers out ? and does looks like i have to drop the subframe to get the tranny out Link to comment Share on other sites More sharing options...
ehsnils Posted October 24, 2011 Share Posted October 24, 2011 Just make sure that the rear diff has the same ratio or replace the rear diff at the same time. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 25, 2011 I Donated Share Posted October 25, 2011 You dont have to drop the subframe. - remove exhaust - remove exhaust heat shield - remove driveshaft - remove CVs - remove starter - remove shift linkage - remove flexplate bolts - remove bellhousing bolts - remove trans mount & crossmember - remove trans The trick to removing the CVs is there is a pin that holts the inner part of the axle to the trans. You have to knock it out with a punch and hammer. Its called a spring pin. Go to the Subaru dealer and buy two new ones, because they usually get destroyed when you remove them. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
travgag Posted October 25, 2011 Author Share Posted October 25, 2011 Great ! thanks Link to comment Share on other sites More sharing options...
travgag Posted October 27, 2011 Author Share Posted October 27, 2011 Okay, i got the old trans out, then realized the axle seals on the new one are shot, i took them out and replaced them with the old ones that were in good condition, I didn't actually pull out the seal from the cover, I swapped the covers, then tried to replace them at the same torque. I read that I can blow my diff bearings if there not correctly torqued where they were, So now I cant get the trans into place, me and my father on the ground trying to get it in are having a hard time, we managed to the a floor jack under the transfer case but that's not a center point to actually lift the entire trans, anyone tackle this ? im thinking maybe a come-along and try to pull it from the top. anyways its late, il try it again tomorrow Link to comment Share on other sites More sharing options...
