Subieaction Posted October 18, 2011 Share Posted October 18, 2011 I just noticed after my clutch started going is that when I am parked and turn my steering wheel to get out of parking spaces there is a extremely heavy vibrations. I popped the hood and started turning the wheel and can some vibrations coming from a line from the steering wheel to the engine. I have never heard of anything like this, I could really use some help. Thanks chris Link to comment Share on other sites More sharing options...
frank_ster Posted October 18, 2011 Share Posted October 18, 2011 well first thought would be low power steering fluid causing cavatation of the pump that would describe some of that Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Subieaction Posted October 18, 2011 Author Share Posted October 18, 2011 I will check that when I get off from work thanks Link to comment Share on other sites More sharing options...
Subieaction Posted October 19, 2011 Author Share Posted October 19, 2011 So I checked my levels and they are fine. I asked my friend and he said it could be a timing belt issue. But how do you check the timing belt for wear and tear?? Link to comment Share on other sites More sharing options...
Max Capacity Posted October 19, 2011 Share Posted October 19, 2011 So I checked my levels and they are fine. I asked my friend and he said it could be a timing belt issue. But how do you check the timing belt for wear and tear?? That's a new one on me... timing belt cause a steering issue....? May be he meant the drive belt for the PS pump. It may be time to take it to a repair shop and have them check it out and replace what is going bad. Remember this is your steering were talking about. Not something you want to get wrong. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AZP Installs Posted October 19, 2011 Share Posted October 19, 2011 There are only a few lines for the whole power steering system that you can see without going under the car. There are the 2 lines coming up from the passenger side that go into the pump and reservoir. Then there is the steering column coming from the wheel itself to the rack on the driver side. You said that your levels are fine on fluids so I will rule out being low etc. As Max said the drive belt for the power steering pump might be loose or bad. The belt should not show signs of cracks, or missing ribs. If it does replace it. There should be no reason your timing belt would cause issue with your steering. -Jake http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg Call directly for your best Whiteline Price! | We also carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Subieaction Posted October 24, 2011 Author Share Posted October 24, 2011 Yeah I am dropping it off at the shop tomorrow to have it all checked at because it is getting worse now. Thank you all for the quick responses back. Link to comment Share on other sites More sharing options...
mperez865 Posted October 26, 2011 Share Posted October 26, 2011 i second the timing belt issue Link to comment Share on other sites More sharing options...
kris4mica Posted November 1, 2011 Share Posted November 1, 2011 any update on this. I have an 07 with 114K miles on it. My car is going in for the timing belt within the week or so. curious to hear what it is Link to comment Share on other sites More sharing options...
Subieaction Posted November 2, 2011 Author Share Posted November 2, 2011 They still don't know but giving a call back to my local shop today to find out the problem and how much it will cost me Link to comment Share on other sites More sharing options...
