TRSCobra Posted October 17, 2011 Share Posted October 17, 2011 http://i12.photobucket.com/albums/a204/TRSCobra/286126384_photobucket_11312_.jpg It's only happening on my left rear door right now, but does anyone know a of a long lasting, cheap (i.e. rubber cement) fix that won't look like crap? I haven't priced these from the dealer, but I can't imagine they're less than $50. Link to comment Share on other sites More sharing options...
Schrei Wolf Posted October 17, 2011 Share Posted October 17, 2011 I had an issue like this with my Camaro, my fix was Black Permatex Gasket Maker Link to comment Share on other sites More sharing options...
TRSCobra Posted October 18, 2011 Author Share Posted October 18, 2011 Thanks for the recommendation; I have some in the garage that I might end up trying. I can't imagine it would hold up too well in that spot, though. It flexes every time the door opens or closes, and people often touch it when they close the door. Link to comment Share on other sites More sharing options...
Schrei Wolf Posted October 18, 2011 Share Posted October 18, 2011 Also use something around it so you don't glue your door shut.... Link to comment Share on other sites More sharing options...
PirateDuck Posted October 19, 2011 Share Posted October 19, 2011 I ended up carefully trimming mine off. I cut it so that it mated up with the other lines on the body. You'd never know it was not supposed to look like that. Link to comment Share on other sites More sharing options...
TRSCobra Posted October 19, 2011 Author Share Posted October 19, 2011 ^^^ Can you post a pic? Link to comment Share on other sites More sharing options...
PirateDuck Posted October 20, 2011 Share Posted October 20, 2011 I'll post some later. I tried to take a pic with my camera phone in the garage at work and it looks really bad. Sunlight and no flash should help. Link to comment Share on other sites More sharing options...
GTTuner Posted October 20, 2011 Share Posted October 20, 2011 I ended up carefully trimming mine off. I cut it so that it mated up with the other lines on the body. You'd never know it was not supposed to look like that. This ^ Link to comment Share on other sites More sharing options...
Nuclear Posted October 24, 2011 Share Posted October 24, 2011 I had cut it off. Link to comment Share on other sites More sharing options...
LucaBrasi Posted October 26, 2011 Share Posted October 26, 2011 I have the same problem on both of my rear doors....I'd be interested to see pics of the trim jobs also. Link to comment Share on other sites More sharing options...
jahousafat Posted October 28, 2011 Share Posted October 28, 2011 I ended up carefully trimming mine off. I cut it so that it mated up with the other lines on the body. You'd never know it was not supposed to look like that. +1 A new razor blade and a careful hand can trim that off like it was factory. Mine bothered be for over a year before I decided to cut them off myself. Link to comment Share on other sites More sharing options...
TheBlubaru Posted October 28, 2011 Share Posted October 28, 2011 subscribed looking for a solution as well God created turbo lag to give V8s a chance Link to comment Share on other sites More sharing options...
underpowerd Posted October 29, 2011 Share Posted October 29, 2011 3m outdoor doubleside tape on the inside of the torn seam. just put a peice of electric tape over the exposed inner side. practically invisible, and lasts forever (has been holding mine like a rock for well over a year). Link to comment Share on other sites More sharing options...
