jamaha51 Posted October 12, 2011 Share Posted October 12, 2011 Ok, I had to weld the bumper support on my frame and am having some problems. I read up and almost everybody said to unhook the battery which I did. But after welding, the power windows, sun roof, gauges, and heater and A/C fan doesn't work. I checked the fuses and replaced two but I couldn't find any fuses for the above problems. Is there a third fusebox I can't find somewhere? Sorry for being such a newb:rolleyes: Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 12, 2011 I Donated Share Posted October 12, 2011 NOOB!!!!!!! lol jk its all good. There is only the box in the cab and the one under the hood. Pull EVERY fuse regardless of what you thinks its for and check the condition of it. As well, in the fuse box under the hood there is a fusible link that controls all the accessories. Ive blown it before and it was interesting to diagnose lol. Its a green box looking thingy. One is for the ECU and one is for the accessories. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
jamaha51 Posted October 15, 2011 Author Share Posted October 15, 2011 Where the fusible link should be it is just a wire to connect them and all of the fuses including the green 30a box ones are fine. Also, my alternator is not working so and it is just running off the battery. I don't even know where to start with electrical crap besides taking the alternator to get tested. How would I diagnose the accessory stuff? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 15, 2011 I Donated Share Posted October 15, 2011 Is the charging system light in your gauge cluster on? Does it work when you first turn on the car. If this light is blown, your alternator wont work -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
jamaha51 Posted October 15, 2011 Author Share Posted October 15, 2011 Ok, how would you recommend finding the problems with the accessories though? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 15, 2011 I Donated Share Posted October 15, 2011 I couldnt tell you. Electrical gremlins are my weak spot -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Stang70Fastback Posted October 16, 2011 Share Posted October 16, 2011 Electrical gremlins are my weak spot http://i183.photobucket.com/albums/x187/RC924/gremlins_posterhttpforumsrennlistco.jpg Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 16, 2011 I Donated Share Posted October 16, 2011 ^awesome -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
MikeSomething Posted October 16, 2011 Share Posted October 16, 2011 Sorry to jump in here... My Dome Light, Cruise Control, HVAC Lights, & front windshield washer pump do not work at all... Everything else works fine, and all the fuses for each are ok. Tell me how you blow a fusible link?????????? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 16, 2011 I Donated Share Posted October 16, 2011 A fusible link should only blow if there is a short in the wiring harness somewhere....but if your accessory fusible link blew, NONE of your accessories would work at all...except for your headlights and brake lights -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
MikeSomething Posted October 17, 2011 Share Posted October 17, 2011 A fusible link should only blow if there is a short in the wiring harness somewhere....but if your accessory fusible link blew, NONE of your accessories would work at all...except for your headlights and brake lights Ok, so if it did blow, should I just replace that wire which is jumping the two connections?? Link to comment Share on other sites More sharing options...
jamaha51 Posted October 26, 2011 Author Share Posted October 26, 2011 Could it be a ground went bad for some reason? I am going to take all of the fuses out and test them but that is all I know to do. Link to comment Share on other sites More sharing options...
