urdrwho Posted October 11, 2011 Share Posted October 11, 2011 A month ago when my son got the car I cleaned the MAF with MAF spray. He came home last night, parked the car, it was running fine. This morning I was going to use it and it would not keep idling, the AT dash light was coming on and it threw a code. It would not move without stalling. Checked the code and it was P100 - a MAF code. I checked the air cleaner and it was fine and newLooked for restrictions in the intake running to the air cleaner and it was fine.So I took the MAF out sprayed it well with MAF cleaner, sprayed the connector and put it back together. It now runs fine. Wonder what miffed my MAF? Weird event and wouldn't have been a good event if it happened while away from home. Wonder why...any ideas? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 11, 2011 I Donated Share Posted October 11, 2011 Replace the mass air flow sensor? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
subikid90 Posted October 12, 2011 Share Posted October 12, 2011 What kind of air filter are you using? Is it an oiled filter, like a k&n? I have heard that they can put a coating on the MAF and cause many problems. Also you may so some reason have oil in the intake tube/box that could cause the same issue. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted October 12, 2011 Share Posted October 12, 2011 Look into replacing the MAF Link to comment Share on other sites More sharing options...
urdrwho Posted October 13, 2011 Author Share Posted October 13, 2011 I'm going to take a wait and see on this one. Prices for a new MAF range from $65 to $295. Maybe all the cleaning of the intake allowed something to go backward to the MAF element. Replace the mass air flow sensor? Link to comment Share on other sites More sharing options...
urdrwho Posted October 13, 2011 Author Share Posted October 13, 2011 Regular filter. What kind of air filter are you using? Is it an oiled filter, like a k&n? I have heard that they can put a coating on the MAF and cause many problems. Also you may so some reason have oil in the intake tube/box that could cause the same issue. Link to comment Share on other sites More sharing options...
johnegg Posted October 13, 2011 Share Posted October 13, 2011 maybe the wire connector wasn't tight, and it loosened up over time. then the r&r fixed it. Link to comment Share on other sites More sharing options...
