IRNChip Posted October 4, 2011 Share Posted October 4, 2011 Here's the fix to a problem I just had on my 2005 Legacy GT wagon (5MT): The seat belt chime kept going off even though I was belted. The airbag light was on. The power door locks didn't work. Under each front seat is a wire bundle with a plastic end that doesn't plug into anything. Apparently it is for a tire pressure monitor set-up that my car doesn't have. The one under my car's passenger seat corroded due to lots of water (I suspect the window was left down overnight by the person who borrowed the car). The corrosion caused a short. Removing the corroded bit and wrapping the wire ends separately solved the problem. We spent several hours chasing it down. Hopefully you find this thread if you have the same problem. Link to comment Share on other sites More sharing options...
charlie_sheen Posted October 4, 2011 Share Posted October 4, 2011 thanks for posting the problem! i havent had it yet, but im sure someone who does will find this and save them the annoyance. Link to comment Share on other sites More sharing options...
tnrst1 Posted October 4, 2011 Share Posted October 4, 2011 A vacuum job can pull that loose. Link to comment Share on other sites More sharing options...
imblaze89 Posted July 21, 2013 Share Posted July 21, 2013 Help! Same problem seatbelt chime and airbag light just started last night.. So under my seat there is a yellow plug that's not plugged into anything could that be it? It's looks to be in pretty good shape but I can't get to it did u take your seat out? Link to comment Share on other sites More sharing options...
cpt morge maker Posted July 21, 2013 Share Posted July 21, 2013 I have just the passenger seatbelt chime going off on mine. Airbag lights says off with no one in it and on when there is someone in it but no matter what when the seatbelt is unbuckled it is beeping and flashing untill I plug it in. Link to comment Share on other sites More sharing options...
chimera Posted July 21, 2013 Share Posted July 21, 2013 this post provides some good info http://legacygt.com/forums/showthread.php/final-disable-seat-belt-chime-52672.html Link to comment Share on other sites More sharing options...
