oxymoron36 Posted October 3, 2011 Share Posted October 3, 2011 hey i got a 97 gt with the 2.5, im taking the engine out to do my headgaskets and im planning on replacing my clutch and getting a lightened flywheel as well as getting sti engine mounts. any other simple mods i should do? and any maintenance/replacing i should do while the engines out? any advice, suggestions, and links provided will be very helpful! thanks! Link to comment Share on other sites More sharing options...
lulzcow Posted October 3, 2011 Share Posted October 3, 2011 If you are replacing engine mounts, get the STi Group N. Should definitely pick up the same transmission mount as well as pitch stop mount. I literally got all those installed today and they really make a world of difference in responsiveness, handling, sound.. Since you have the engine out it might be a good idea to get upgraded pulleys. RS headers. MSD ignition. Intake. Paint and engine dress up while it is out. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 3, 2011 I Donated Share Posted October 3, 2011 sti mounts are a waste of money. If you want better mounts, go with Group N engine and transmission mounts. Stage 1 clutch kit and lightweight flywheel are good mods, as well as a light weight crank pulley. You can put intake spacers on there...not sure where to buy them Have you looked at the aftermarket upgrade FAQ at the top of the forum? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Baddog Posted October 3, 2011 Share Posted October 3, 2011 sti mounts are a waste of money. If you want better mounts, go with Group N engine and transmission mounts. Stage 1 clutch kit and lightweight flywheel are good mods, as well as a light weight crank pulley. You can put intake spacers on there...not sure where to buy them Have you looked at the aftermarket upgrade FAQ at the top of the forum? Grimmspeed Link to comment Share on other sites More sharing options...
johnegg Posted October 3, 2011 Share Posted October 3, 2011 once the flywheel is off, check the ''oil sep plate'' on the back of the engine. they leak. the replacement metal plate, a must do if yours it is plastic, and highly recommended if yours is aluminum, is not expensive., about $25. (you need the screws too.) at the very least you need to reseal it with RTV ultra gray. do not use too much sealant, it can glob up on the inside and travel to the cam shaft and block an oil channel. have fun. Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 3, 2011 Share Posted October 3, 2011 Do all the seals, while you are in there. Also install a new tensioner when you install your new timing belt. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
oxymoron36 Posted October 3, 2011 Author Share Posted October 3, 2011 good stuff guys, thanks a million! yeah ive checked the FAQ and that was helpful too, im just checking to see what you guys have done to know whats worth the money and time to do it Link to comment Share on other sites More sharing options...
Jab83 Posted October 3, 2011 Share Posted October 3, 2011 sti mounts are a waste of money. If you want better mounts, go with Group N engine and transmission mounts. Stage 1 clutch kit and lightweight flywheel are good mods, as well as a light weight crank pulley. You can put intake spacers on there...not sure where to buy them Have you looked at the aftermarket upgrade FAQ at the top of the forum? thats what lulz what saying.... getting STI group n engine and transmission mounts.... lol. I didn't see any made for our cars. @_@ so STI/wrx they would be called. Link to comment Share on other sites More sharing options...
oxymoron36 Posted October 6, 2011 Author Share Posted October 6, 2011 hey for that set of mounts, the 02-07 wrx sti ones will fit right? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 6, 2011 I Donated Share Posted October 6, 2011 yes they will -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 6, 2011 Share Posted October 6, 2011 What is a good light weight crank pulley to purchase? Since I'll be in there next week. Also, what is a good way to clean all the gunky oil and dirt off of the engine? Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 6, 2011 Share Posted October 6, 2011 I was checking out prices on light weight pulleys: http://www.infamousperformance.net/servlet/Categories Guess I should have researched a bit before I asked. They're kind of expensive ($115-135). Can you really feel that much of a difference? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 6, 2011 I Donated Share Posted October 6, 2011 I have never done just a light weight crank pulley alone...so I don'tknow how much of a difference it makes...however a light weight crank pulley paired with a light weight flywheels makes the engine much more free reving. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
lulzcow Posted October 6, 2011 Share Posted October 6, 2011 I have a lightweight pulley from Perrin that is going in this weekend. My car has already had a lightweight flywheel before I purchased it, so I can let you know what kind of difference the Perrin pulley has once it gets installed. Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 7, 2011 Share Posted October 7, 2011 ej25turbo has an underdriven crank pulley for a good price but I have read mixed reviews about them... Safer to go with a 'normal size'? I don't want to cause any trouble now. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 7, 2011 I Donated Share Posted October 7, 2011 Poorly designed cheap pulleys or copies and knock-offs of major brands can have severe side effects because of too much underdrive of the alternator, power steering, and/or air conditioning units, which are not spinning fast enough. These lead to dips in alternator voltage, power assist, and air conditioning effectiveness that may be noticeable, especially at idle. The headlights may dim when coming to a stop, or the stereo may lower in volume, for instance. Too much underdrive for a race car is not much of a concern, but for a daily driven vehicle it can be a major annoyance. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted October 7, 2011 Share Posted October 7, 2011 All my lights inside and outside the car Dim when i touch the brakes let me tell you it sucks. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 7, 2011 I Donated Share Posted October 7, 2011 Do you have an underdrive pulley? or do they just do that randomly? Have you done the grounding mod? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted October 8, 2011 Share Posted October 8, 2011 I have no idea what has been done to it other than what i have done..And it does everytime i hit the pedal. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 8, 2011 I Donated Share Posted October 8, 2011 You need to do the "Subaru Grounding Mod". Search for it on Google. I bet it will fix your problem. EVERYONE should do this mod -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Jab83 Posted October 8, 2011 Share Posted October 8, 2011 Yes... I took mine off cause i'm gonna change the terminals and it runs like crap now . :/ Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 8, 2011 I Donated Share Posted October 8, 2011 took off your grounding mod? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 8, 2011 Share Posted October 8, 2011 Wait a sec, what is the definition of an underdriven pulley? The GrimmSpeed pulley people state that they are underdriven: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120789179582&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Quote: "Lightweight Crank Pulleys reduce parasitic drag placed on the crankshaft by under driving the accessories such as Alternator, Power Steering and Air Conditioning. Under driving slows down the accessories to use less energy from the crankshaft but doesn't slow them down to the point the accessory operation becomes effected. Most of the power gains are produced from the lightened weight of the crank pulley. Tests show that an average of 2.7 HP is gained from every pound of weight that is reduced from the crankshaft." So are all lightweight pulleys underdriven? That doesn't seem right. Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted October 8, 2011 Share Posted October 8, 2011 I'll check it out Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted October 8, 2011 I Donated Share Posted October 8, 2011 Not all lightweight pulleys are under drive pulleys.... Just ones that are a different size and lighter are under drive. stock size and light is just lightweight -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
