nsrt4me Posted September 30, 2011 Share Posted September 30, 2011 I thought my clutch was starting to slip, but wasnt that bad so I ignored it. yesterday, i did a drop to 4th to pass on the hw, and the car went no where. Did a few tests, clutch was slipping bad. Even in 3rd gear it slips hard when i try to accelerate any more than normal. As of now my car is stock, however, i will be going stage 2 very soon, so i need a clutch that can handle the torque and abuse, along with daily driving. later down the road I plan on going bigger turbo (hta68) so it would be nice to get a clutch that would work for stg 2 and down the road. What clutch do you guys recommend for stage 2 power, that can take a bit of moderate launching, and DD? Im looking between the clutchmasters fx200 and fx300 right now, I like the exedy stg 2+ but dont know anyone that runs exedy personally. Thanks. Link to comment Share on other sites More sharing options...
nsrt4me Posted September 30, 2011 Author Share Posted September 30, 2011 Correction*** I didnt mean exedy, I meant to say im looking at the SPEC stg2+ also . Share your thoughts. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 30, 2011 Share Posted September 30, 2011 Search in this forum. I have one of the first Spec 2+ and at 74,000 mile it still love it. Its a high perfromce clutch, no doubt it. It's a bit harder to push in then my 09 SpecB with the OEM clutch. But I don't find it bad in traffic. It will chatter a bit when it's damp out, but I have found that if I just side step the clutch in neutral the chatter stops. The clutch has seen abruse and still hooks up like new. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
