PearlBlueGT Posted September 22, 2011 Share Posted September 22, 2011 So I need a new ECU (CEL is on for evap solenoid and it's in good condition) How much does it run? Link to comment Share on other sites More sharing options...
bmx045 Posted September 22, 2011 Share Posted September 22, 2011 The ecu was probably making the ticking noise, you really should replace it. Ecu's from the dealer are towards $600. Find a used one. Link to comment Share on other sites More sharing options...
Lardo420 Posted September 22, 2011 Share Posted September 22, 2011 you should just buy a new car Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted September 23, 2011 Share Posted September 23, 2011 $110 used off ebay for an '05, but do your due diligence and make sure its compatible. Would think other model years would be comparable price. Dealer has to link it up for you though due to the immobilizer issue. Here you go. http://cgi.ebay.com/ebaymotors/_W0QQcmdZViewItemQQ_trksidZp3984Q2em1423Q2el2649QQitemZ230513837438QQsspagenameZSTRKQ3aMEWAXQ3aIT Also you can find a ton more by going to: http://www.car-part.com Good luck. Link to comment Share on other sites More sharing options...
__raj Posted September 23, 2011 Share Posted September 23, 2011 So I need a new ECU (CEL is on for evap solenoid and it's in good condition) How much does it run? Sure sounds like throwing parts at the car. Have you checked the wiring and other related items. A CEL does not always mean change a part. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 23, 2011 Author Share Posted September 23, 2011 yes, my mechanic (subaru mechanic) took it to work and checked it all out. sensor works and most probably cause is bad ECU Link to comment Share on other sites More sharing options...
bmx045 Posted September 23, 2011 Share Posted September 23, 2011 fishy Link to comment Share on other sites More sharing options...
jmatijas_gt Posted September 23, 2011 Share Posted September 23, 2011 see if you are eligible for the Service bulletin RE: radiator fan staying on. Dealer replaced my ECU ($1100) and i was at 80k miles. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted September 23, 2011 Author Share Posted September 23, 2011 $110 used off ebay for an '05, but do your due diligence and make sure its compatible. Would think other model years would be comparable price. Dealer has to link it up for you though due to the immobilizer issue. Here you go. http://cgi.ebay.com/ebaymotors/_W0QQcmdZViewItemQQ_trksidZp3984Q2em1423Q2el2649QQitemZ230513837438QQsspagenameZSTRKQ3aMEWAXQ3aIT Also you can find a ton more by going to: www.car-part.com Good luck. It says 2.5 without turbo so it won't work on my car, am I correct? Link to comment Share on other sites More sharing options...
bmx045 Posted September 23, 2011 Share Posted September 23, 2011 You'll need the same year, turbo, ecu Link to comment Share on other sites More sharing options...
Heedz Posted September 24, 2011 Share Posted September 24, 2011 I have a 05 gt ecu. Just needs to be sent to tactrix to be unbricked. Lemme know via pm. Ill sell it for cheap. It was in great condition before it bricked when voltage spiked during a map Link to comment Share on other sites More sharing options...
__raj Posted September 24, 2011 Share Posted September 24, 2011 >80k miles I assume? Link to comment Share on other sites More sharing options...
PearlBlueGT Posted November 3, 2011 Author Share Posted November 3, 2011 got another ECU on there and no more CEL Link to comment Share on other sites More sharing options...
No DRFT Posted November 3, 2011 Share Posted November 3, 2011 I have a 05 gt ecu. Just needs to be sent to tactrix to be unbricked. Lemme know via pm. Ill sell it for cheap. It was in great condition before it bricked when voltage spiked during a map Glad OP got his car fix. But a bit OT, how did the voltage spiked? I have no control over drippie. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted November 4, 2011 Author Share Posted November 4, 2011 I'm glad to have it fixed too. I have found Subaru mechanic who is very knowledgeable and works at Subaru. Dealers wanted $750-$900 for the ECU, got it off of Ebay for $100 shipped. Link to comment Share on other sites More sharing options...
