davenz Posted September 21, 2011 Share Posted September 21, 2011 Hi guys im Dave from NZ. I have a 2004 LGT Manual. Now over in nz we only have the 2L single turbos in that model. So its an ej20t. Now the thing is this mate i no has told me not to waste my time on doing my car up. Below is the convo that i had with him. He has done the following to his car. 1996 wagon (was NON STI) 2.2 sti v4 fully forgded 275 degree lumpy cams forgy acr bearings con rods wisco forgy pistons 2.5 litr crank shaft to much to list link g4 two 500 fuel pumps nah all ra sti running gear 5 puk brss button clutch i said to him im just thinking wht i should do 2 my car.. He said not worth it to be onest bro those legacy are kaka for performance u need the 3litr out of the sti leagacy single turb wagon 2006 shape Is he correct and would his car be fast? im new to subbies so please advise Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 21, 2011 Share Posted September 21, 2011 Hi Dave. Welcome. Your mate is full of it. 1) There has never been a 3-liter turbo. 2) The EJ20 is a fine engine to make some power out of. Something doesn't add up with his car. If it's got a 2.5L crank, then it's 2.35L not 2.2L. The STi never came with a 2.2L, unless it was a 22B (which his isn't, and he doesn't have the motor from). Just follow the normal formula. Exhaust and tune, then see if you want more out of it or not. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
davenz Posted September 21, 2011 Author Share Posted September 21, 2011 he said that its a stroker lol and i thought it didnt sound right so thats y i asked Link to comment Share on other sites More sharing options...
boymk123 Posted September 21, 2011 Share Posted September 21, 2011 He has done the following to his car. 1996 wagon (was NON STI) 2.2 sti v4 fully forgded 275 degree lumpy cams forgy acr bearings con rods wisco forgy pistons 2.5 litr crank shaft to much to list link g4 two 500 fuel pumps nah all ra sti running gear 5 puk brss button clutch Link to comment Share on other sites More sharing options...
Alfred_Buchi Posted September 21, 2011 Share Posted September 21, 2011 Your friend sounds like he watches fast and furious too much... Please don't listen to anything he ever tells you about your car. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2011 Share Posted September 21, 2011 Stroker, is the term used for increasing the stroke of the engine. So at least he has that right. BAC5.2 knows his stuff, listen to what he say's. Read more on here and you can learn a lot, I'm sure there are guy's here that can link you to other forums about your car and doing mods to it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JLB Posted September 21, 2011 Share Posted September 21, 2011 Like everyone has said you can make good power with our motors... He didn't say anything about this but it is true our 5 speed trannies arent the best they aren't the worst either though. The best option would be 6 speed or you could PPG your gears. That's money though. As for the block you could see good power but at a certain point the stock blow will fail (this is obvious) so you could do build on our motors. The point is our motors are just fine it's almost the same thing as an sti motor(correct me if I'm wrong) but without forged pistons (and of course the 6 speed) I'll leave the post but just reread you're from nz not sure about your cars and this is 2005-2009 forum right?? Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 21, 2011 Share Posted September 21, 2011 Like everyone has said you can make good power with our motors... He didn't say anything about this but it is true our 5 speed trannies arent the best they aren't the worst either though. The best option would be 6 speed or you could PPG your gears. That's money though. As for the block you could see good power but at a certain point the stock blow will fail (this is obvious) so you could do build on our motors. The point is our motors are just fine it's almost the same thing as an sti motor(correct me if I'm wrong) but without forged pistons (and of course the 6 speed) I'll leave the post but just reread you're from nz not sure about your cars and this is 2005-2009 forum right?? If it's in NZ, then it's a JDM import most likely. Their BL/BP model years started in 04 (our 2005 model year). [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
JLB Posted September 21, 2011 Share Posted September 21, 2011 Like I said I have no clue about Subaru outside the states haha Link to comment Share on other sites More sharing options...
davenz Posted September 22, 2011 Author Share Posted September 22, 2011 Thanks guys yeah as u can see n my avatar i have a 4th gen i wanna race that dick head now. he be fast?? haha Link to comment Share on other sites More sharing options...
