Andreu Posted September 21, 2011 Share Posted September 21, 2011 a while ago i, and a couple of other people posted topics stating their tranny making a sound similar to the one found in this youtube video: [ame=http://www.youtube.com/watch?v=OGo3wz6t8Jk&feature=related]Subaru WRX Whine - 4th + 5th Gear - YouTube[/ame] Well finally last week my TOB started to scream for attention so i caved in and got a big service. the following was replaced: TOB Clutch disk and pressure plate Flywheel bearing Input and output shaft bearing (AKA main shaft bearing?) Along with a half shaft and a rear wheel bearing (Ohio pot holes) Anyways the output shaft bearing was the culprit to the whining sound you hear in that youtube video. For the visually stimulated forum goers i will post pics of the bad bearings i got back.. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 30, 2011 Share Posted September 30, 2011 Glad you fixed your issue i have the feeling illl have to tear my gearbox down to find it as well which isn't what I wanted to do Link to comment Share on other sites More sharing options...
IronCity06LGT Posted November 9, 2011 Share Posted November 9, 2011 Yeah that's my noise too...any idea how much it costs to fix the output shaft bearing? Link to comment Share on other sites More sharing options...
IronCity06LGT Posted November 9, 2011 Share Posted November 9, 2011 Another example? http://legacygt.com/forums/showpost.php?p=3244961&postcount=32 Link to comment Share on other sites More sharing options...
Subieaction Posted November 19, 2011 Share Posted November 19, 2011 How long did you wait and roughly how much was that? ? I have some noise right now that can almost mirror that Link to comment Share on other sites More sharing options...
Andreu Posted November 20, 2011 Author Share Posted November 20, 2011 How long did you wait and roughly how much was that? ? I have some noise right now that can almost mirror that The sound popped up sometime last year in November or december after I checked my starter motor one night. So a little under a year. I had people tell me I'm crazy and even one "friend" told me that noise was normal. It cost around 700 to drop my tranny and both the input and output shaft bearings were between $20-$50 I believe. I'll have to check my records. So between 800-1000 to fix Link to comment Share on other sites More sharing options...
Subieaction Posted November 21, 2011 Share Posted November 21, 2011 The sound popped up sometime last year in November or december after I checked my starter motor one night. So a little under a year. I had people tell me I'm crazy and even one "friend" told me that noise was normal. It cost around 700 to drop my tranny and both the input and output shaft bearings were between $20-$50 I believe. I'll have to check my records. So between 800-1000 to fix But why is the output shaft making that sound though that is my question? Because it is night and day from when I dropped my car off at the shop to get the clutch/flywheel replaced and taking it home. Should I wait a little longer until it fully breaks in to see if it goes away? Link to comment Share on other sites More sharing options...
