sschmelcke Posted February 5, 2012 Share Posted February 5, 2012 Sorry to bring back this old thread but my stock 7.5 amp fuse blew. My harness was shipped the end of december and i have the 4 pin relay. Its sealed pretty well so taking apart would be a pain. If it was wired incorrectly would it not be possible to take the fuse out and have the horns still work to see if its wired correctly? Link to comment Share on other sites More sharing options...
MadMontie1 Posted March 12, 2012 Share Posted March 12, 2012 I just went to install my Hella Horns which I got for Christmas with the Subimods harness which I purchased around the first of the year. The relay with the Hella Horns is definitely 4 prong, which would result in the 30 connecting to the Black line on the Subimods harness which leads to the spade to stock horn connecting. Mine look EXACTLY like OP photos. Therefore, it seems these 4 prong connectors are definitely still around. SO, my question is, Is the easy fix to somehow swap the black and blue spades in the Subimods harness so that its wired correctly? And if so, is the an easy way to push the spades out and reinsert? Link to comment Share on other sites More sharing options...
gordata Posted September 21, 2014 Share Posted September 21, 2014 Bumping this from the dead but I bought a set of Hellas with the harness either down at the Subaru Maryland event or at WBM and installed them something this summer and I had the 4 pin relay that was draining the crap out of my car over 1 weeks time. Changed the battery because I had drained more then a few times as my car sits over winter but it started to drain the new soon after. Keep a eye out guys. Link to comment Share on other sites More sharing options...
Subimods Posted September 23, 2014 Share Posted September 23, 2014 Bumping this from the dead but I bought a set of Hellas with the harness either down at the Subaru Maryland event or at WBM and installed them something this summer and I had the 4 pin relay that was draining the crap out of my car over 1 weeks time. Changed the battery because I had drained more then a few times as my car sits over winter but it started to drain the new soon after. Keep a eye out guys. If you're still having issues just send us over a PM and we can get this figured out for you. Let us know! Thanks, Justin Link to comment Share on other sites More sharing options...
gordata Posted September 25, 2014 Share Posted September 25, 2014 If you're still having issues just send us over a PM and we can get this figured out for you. Let us know! Thanks, Justin i got it sorted out, came with a 4 pin relay installed, checked that the wiring matched the diagram in this thread and switched to a 5 pin relay and everything is working, hopeful my battery is not shot from draining a few times. Link to comment Share on other sites More sharing options...
