Nexmo.co Posted September 17, 2011 Share Posted September 17, 2011 Ok, So i ordered a new TMIC(360$) a new downpipe (300) new headers and up pipe(400) a garrett gt3076r(1800) and wondering what else i should get, I'm not looking to pump a TON of power right meow, just getting it running with the 3076:spin: Link to comment Share on other sites More sharing options...
robitrice Posted September 17, 2011 Share Posted September 17, 2011 if i am not mistaken that turbo will not bolt up to a LGT style tmic? correct me if i am wrong....but look into upgrading the fuel pump, maybe injectors, upgrade the clutch at the very least and a good tune. Link to comment Share on other sites More sharing options...
bmx045 Posted September 17, 2011 Share Posted September 17, 2011 You'll def need a new pump and clutch... and it will not bolt to a tmic. Also a better bpv. Sorry. Link to comment Share on other sites More sharing options...
Nexmo.co Posted September 18, 2011 Author Share Posted September 18, 2011 I dont see any reason it shouldnt bolt up, ATP stock replacement GT3071R fits with the TMIC. but that will be seen when it shows up I guess :/ my bad if you are correct. I have a stage 2 clutch and LW flywheel already, I have some 850 cc injectors i can put in. Walbro 255 fuel pump sound good? Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 18, 2011 Share Posted September 18, 2011 1) $360 for a stock intercooler is outrageous. You got screwed. 2) The stock intercooler will not be capable of handling a 3076 when used within it's efficiency range. I'm willing to bet that your car will be slower now, than it was with the stock turbo. If you are going with a 3076, you might as well go with a front mount. I'd also start putting away pennies to build a motor. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Nexmo.co Posted September 18, 2011 Author Share Posted September 18, 2011 I didnt say stock, its an IPR Link to comment Share on other sites More sharing options...
Nexmo.co Posted September 18, 2011 Author Share Posted September 18, 2011 What kind of BOV suggestions, I have a friend who has a spare turbo xs bov off his STI, should i just put that on instead of the stock one? Link to comment Share on other sites More sharing options...
bmx045 Posted September 18, 2011 Share Posted September 18, 2011 I like my forge bpv. Great quality... Where are you getting this turbo? I cant find a 3071r that has stock fitment? And sti bov won't fit, different flange. Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 18, 2011 Share Posted September 18, 2011 ATP doesn't make 08+ bolt-on turbos. Shame, too. I'd actually consider one of the GT28RS turbos for my car. That little turbo is a hoss. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Nexmo.co Posted September 18, 2011 Author Share Posted September 18, 2011 The TMIC will need a bridge to the 3076r, I will need to do a few mods to make it work, you're right that it would probably be more worth it to just go front mount at this point, but i reallly enjoy the look and cleanness of top mount. I still need to get a boost controller and BOV on the way :/ that turbo is a hoss? or boss? haha and yeah they spooolll so niceee Link to comment Share on other sites More sharing options...
JLB Posted September 20, 2011 Share Posted September 20, 2011 That sounds like good mods to me sounds like it may put down some good power Link to comment Share on other sites More sharing options...
Nexmo.co Posted September 21, 2011 Author Share Posted September 21, 2011 SO new new plan, (new thread up also) blew that used turbo my friend gave me.... after 20 miles? hmmmm... halp... Link to comment Share on other sites More sharing options...
Max Capacity Posted September 21, 2011 Share Posted September 21, 2011 I see you have very few post here compared to some of us. You should slow down and think about what you need to do first before you spend more money. When your second turbo blew, did it put metal into the oil pan ? Before you put the GT3067r on you better make sure the internals are in good shape. Did you get a oil line kit for that turbo ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
