a.lim Posted September 17, 2011 Share Posted September 17, 2011 My rotors were over-torqued by a clumsy mechanic who used an impact gun to tighten the lug nuts and ever since then I started feeling pulsating effects on my pedal. I just bought new rotors, but I'm afraid the rotors may not be the root of the problem. Can over-torqued wheels cause any other damage besides the rotors? Like the wheel hub getting "warped" too if that is such a thing? Wheel bearing damage? I don't want my brand new rotors to start warping/pulsating again. Link to comment Share on other sites More sharing options...
a.lim Posted December 24, 2011 Author Share Posted December 24, 2011 still trying to confirm.. anyone? Link to comment Share on other sites More sharing options...
Drogos Posted December 24, 2011 Share Posted December 24, 2011 For what it's worth.....way back had issues with vibrations that I couldn't really track down. Someone smart advised to loosen and retorge wheels to specs. Problem went away and never came back at least on that particular set of rotors. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 24, 2011 Share Posted December 24, 2011 So if the mechanic say torqued down one nut all the way before the others, then the rotor's initial seating would not be flush, but instead slightly inward at the corner that was torqued first. So as Drogos said, you just take off the wheel and put it back on by tightening the lug nuts little by little. I start by doing them all figer tight, then a little tight with socket wrench, then torque to spec, all in star-tracing pattern. Basically, you ease all the lug nuts on so they are all close to even. Takes care of the wobble. What you mechanic allegedly did is typical crappy wheel install behavior for people who get lazy with an impact. Impacts are great for removing things, but most usually should not be used for installing things. There is no way to tell how tight the impact is making things, until you have a LOT of practice. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
a.lim Posted December 24, 2011 Author Share Posted December 24, 2011 since it happened im actually on a new set of rotors and i torqued them with the usual procedure I always do, hand tight using star pattern then torque down to spec star pattern... but the problem came back after a couple thousand miles so im convinced something else is damaged like either it is the hub itself (runout) or something more severe. what other parts can cause this vibrating issue? dont want to spend $$$ on new wheel hubs and find out it was something else.. Link to comment Share on other sites More sharing options...
a.lim Posted December 24, 2011 Author Share Posted December 24, 2011 if rotors can warp.. can wheel hubs warp as well? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 25, 2011 Share Posted December 25, 2011 if rotors can warp.. can wheel hubs warp as well? I can't imagine them getting that hot. If the problem came back after a few thousand miles, perhaps (just consider it) your driving and you rotors are not friends. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Drogos Posted December 25, 2011 Share Posted December 25, 2011 I can't imagine them getting that hot. If the problem came back after a few thousand miles, perhaps (just consider it) your driving and you rotors are not friends. I think he was asking if hub can warp from over tourqing ....I have no clue by the way....seems like a stretch Link to comment Share on other sites More sharing options...
compsurge Posted December 25, 2011 Share Posted December 25, 2011 When does the vibration occur? Only under braking? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 25, 2011 Share Posted December 25, 2011 The lug studs should supposedly break before the hub bends, but I don't know much about that. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 25, 2011 I Donated Share Posted December 25, 2011 I have never seen a warped hub from over torqued lugs. Even warped rotors from over torques lugs are less common than people think. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 25, 2011 I Donated Share Posted December 25, 2011 For your vibration....first retorque the wheels. Then machine the rotors. Then start looking for bad axles bushings and front end parts -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
REYSTi Posted December 26, 2011 Share Posted December 26, 2011 I have never seen a warped hub from over torqued lugs. Even warped rotors from over torques lugs are less common than people think. Im been mechanic for over 10yrs. and I agree with broknindarkagain. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 26, 2011 I Donated Share Posted December 26, 2011 Im been mechanic for over 10yrs. and I agree with broknindarkagain. I speak from experience as well. Lug studs generally break before enough stress can be put on other things to warp them. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 26, 2011 Share Posted December 26, 2011 The lug studs should supposedly break before the hub bends, but I don't know much about that. Maybe I do know something afterall [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 26, 2011 I Donated Share Posted December 26, 2011 Maybe I do know something afterall Haha -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
