ohninegt25 Posted November 12, 2011 Author Share Posted November 12, 2011 With new turbo... Red - Stock turbo Tune Blue - 440 turbo Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 12, 2011 Share Posted November 12, 2011 Very nice! Hows the transmission feel? Link to comment Share on other sites More sharing options...
ohninegt25 Posted November 12, 2011 Author Share Posted November 12, 2011 Thanks... trans is good. going to change tran fluids when I do regular oil changes though. While they were dynoing it, the said the trans cooler was so hot that you could brand your hand if touched it. Link to comment Share on other sites More sharing options...
TRSCobra Posted November 13, 2011 Share Posted November 13, 2011 Time for a bigger trans cooler! Link to comment Share on other sites More sharing options...
ohninegt25 Posted November 23, 2011 Author Share Posted November 23, 2011 scoobydoobie... off topic, how do you keep these darn 'rear roof spoilers' on? Double sided tape isn't cutting it! Link to comment Share on other sites More sharing options...
MatsuDano Posted November 23, 2011 Share Posted November 23, 2011 in for the numbers. Link to comment Share on other sites More sharing options...
ohninegt25 Posted November 23, 2011 Author Share Posted November 23, 2011 That's right! New shoes coming in soon! Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 23, 2011 Share Posted November 23, 2011 scoobydoobie... off topic, how do you keep these darn 'rear roof spoilers' on? Double sided tape isn't cutting it! Double sided tape . Use 3M automotive with the red backing. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted November 23, 2011 Share Posted November 23, 2011 Double sided tape . Use 3M automotive with the red backing. Which rear window spoiler do you have ??? ( I think i asked once but forgot) Link to comment Share on other sites More sharing options...
bmx045 Posted November 23, 2011 Share Posted November 23, 2011 valve body tranny mod isn't available for 08-09 5eat's yet but it's coming soon. IPT makes fully built 5eat tranny's that are ready for drop in if you're really wondering what you can do. some guy on here is running a 40r turbo with the ipt auto tranny. Link to comment Share on other sites More sharing options...
scoobydoobie Posted November 23, 2011 Share Posted November 23, 2011 Which rear window spoiler do you have ??? ( I think i asked once but forgot) Stanza Link to comment Share on other sites More sharing options...
ohninegt25 Posted December 24, 2011 Author Share Posted December 24, 2011 valve body tranny mod isn't available for 08-09 5eat's yet but it's coming soon. IPT makes fully built 5eat tranny's that are ready for drop in if you're really wondering what you can do. I'm going down this road, I can't take it anymore Just IPT huh? Link to comment Share on other sites More sharing options...
ohninegt25 Posted December 24, 2011 Author Share Posted December 24, 2011 I do. How long? Link to comment Share on other sites More sharing options...
ohninegt25 Posted February 13, 2012 Author Share Posted February 13, 2012 BACK in the shop for knocking in the engine, engineer says "rebuild or sti block" Or if there are any ideas out there!? Truly BUMBED OUT! Link to comment Share on other sites More sharing options...
iNVAR Posted February 14, 2012 Share Posted February 14, 2012 What did they say happened? Because from your other thread, sounds like someone (not pointing fingers) made a booboo. Link to comment Share on other sites More sharing options...
06_legacygt Posted February 15, 2012 Share Posted February 15, 2012 i agree. there was most definatly and issue with your tune. i would present a copy on that datalog to your tuner and tell him to fix it 2006 Legacy GT 5EAT Perrin UP, SPT CAI, OBXR CBE, Catless DP, Perrin TMIC, Stage 2 AP tune Soon after BNR 16G, Infamous Tune Link to comment Share on other sites More sharing options...
ohninegt25 Posted February 15, 2012 Author Share Posted February 15, 2012 What did they say happened? Because from your other thread, sounds like someone (not pointing fingers) made a booboo. i agree. there was most definatly and issue with your tune. i would present a copy on that datalog to your tuner and tell him to fix it The shop (title of the thread) hasn't responded back to me (might be a little embarrassed) about this... so I took it to another shop and they told me that "by the sounds of things, it could be a piston issue but they can't be 100% until they take it apart." I will post the reason later. Guess this will be an expensive lesson... I just keep telling myself that the car will be back and even stronger! Link to comment Share on other sites More sharing options...
iNVAR Posted February 15, 2012 Share Posted February 15, 2012 Your datalogs look like your MAF sensor was capped out. Being unable to meter the air appropriately, your car probably leaned out, causing some really bad detonation at WOT. I'd be wondering why your tuner didn't notice that during the tune... and I'd also want to know if they'll foot the bill being that if I'm right, they caused this problem... Link to comment Share on other sites More sharing options...
ohninegt25 Posted February 16, 2012 Author Share Posted February 16, 2012 Thanks for the input on this matter gentlemen... Here is the response to this issue... The data from the log is unclear, but it looks like the car was overboosting, and/or had a leak somewhere. The Boost column shows as much as 24 psi, but then has erroneous data through a good part of the log. I'm not sure what it means when the boost column starts reading random very large numbers (41902?), but I'd say it's not good. I do see the MAF voltage at 5 volts -- I never saw that much voltage when I was tuning and logging the car. Looking back through all my previous logs, I never see voltages anywhere near that high. If there's a leak in the pressurized piping you can see very large MAF numbers. I really can't deduce more about what happened with the engine without more information; at best I'd be guessing. O: Link to comment Share on other sites More sharing options...
iNVAR Posted February 16, 2012 Share Posted February 16, 2012 What's your map's target boost? Safety limit should've been hit and a CEL should've been thrown. A leak in a pressurized portion of your intake should've caused you to underboost, not overboost. Again, just my thoughts on the matter, don't take what I say as gospel. Link to comment Share on other sites More sharing options...
ohninegt25 Posted February 17, 2012 Author Share Posted February 17, 2012 Target boost is 23... The start... :spin::spin::spin: Link to comment Share on other sites More sharing options...
iNVAR Posted February 17, 2012 Share Posted February 17, 2012 If the stock boost sensor is limited at about 23-24 psi, I have no idea how you're supposed to keep using that, have a target of 23psi, and still be able to have a safety cutoff to throw a CEL... You have no safety margin at all. But even before you hit the boost limit, looking at the datalogs you posted up in your other thread, you clearly hit 300g/s (5V) on your MAF sensor at 16.34 PSI. WELL before your boost limit. Link to comment Share on other sites More sharing options...
ohninegt25 Posted February 17, 2012 Author Share Posted February 17, 2012 Thanks man... great points! The crew at MACHV are great! But this broke my trust and my wallet... so I'm putting my eggs in another shop! Link to comment Share on other sites More sharing options...
bigkfromIL Posted February 17, 2012 Share Posted February 17, 2012 check his afr's on the dyno sheet. he tapers to mid 11's, and then just before redline low 11's. this leaves NO room for knock or maf/intake problems. he said he used an extension for cold air, spiking maf voltages can occur when there's not enough restriction in the intake pre maf- like a filter falling off. the maf couldnt have been damaged because that would have more than likely sprung a CEL. i think his af's leaned out a little bit and pistons went pop Link to comment Share on other sites More sharing options...
iNVAR Posted February 17, 2012 Share Posted February 17, 2012 That's not what he's running anymore. Check post #9 and 26 for the dyno. Thanks all... but Going BIGGER! Any thoughts? ON RIGHT NOW: SPT cat-back exhaust SPT short-ram - extension added for colder air intake Invidia Downpipe Catted Prosport EL Header and Up-pipe AVO intercooler boost control solenoid transmission cooler MADE: approx 250hp & 270tq INSTALLED IN A FEW WEEKS: · Blouch 440XT turbo with 7cm2 housing · Black ceramic coating on turbine housing · Black ceramic coating on compressor housing · Braided oil feed line for LGT · HPD compressor upgrade · Deatschwerks 750cc top feed fuel injectors · TGV gaskets · 08+ STI fuel pump · Turbo inlet · 3”-2 ¾” coupler for inlet to intake and then a Protune HP gains? Thanks again and looking forward to any sugguestions Link to comment Share on other sites More sharing options...
