dbob3d Posted September 13, 2011 Share Posted September 13, 2011 Hello, My 1998 Legacy GT is vibrating at 50-60mph. It doesn't vibrate at speeds lower or speeds higher than this range. It is as smooth as a car should be outside this range. The vibration isn't just a steering column vibration, its the whole car vibrating. Could this be a wheel bearing? I just had a mechanic put new tires on this car, could their balance be the issue? I just can't see shelling out another $600 for another wheel bearing replacement, so... Be honest, what is it? Link to comment Share on other sites More sharing options...
Highflyr Posted September 13, 2011 Share Posted September 13, 2011 Improperly balaced wheels. Bearings don't really vibrate they hum or make a bunch of noise when turning one way or another. Link to comment Share on other sites More sharing options...
Jab83 Posted September 13, 2011 Share Posted September 13, 2011 dude wtf? stop making more and more threads. your Wheels need balanced.. all there is to it. I had same problem. I painted rims so took of my wheel weights and it was really bad from 60 to 80ish it was bad... Link to comment Share on other sites More sharing options...
Baddog Posted September 14, 2011 Share Posted September 14, 2011 I thought mine was needed to be rebalanced as well. But I have had mine done 3 times. The problem is still there for me. But it goes from 50mph all the way up. Link to comment Share on other sites More sharing options...
Jab83 Posted September 14, 2011 Share Posted September 14, 2011 bent axles? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 14, 2011 I Donated Share Posted September 14, 2011 Bearings don't really vibrate they hum or make a bunch of noise when turning one way or another. You haven't come across many bad wheel bearings then. They can hum, squeal, vibrate, grind, etc. I just can't see shelling out another $600 for another wheel bearing replacement You paid $600 for a wheel bearing? You got ripped off. REALLY BAD Check your tire balancing again. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SBT Posted September 14, 2011 Share Posted September 14, 2011 If you're posting from a mobile device, please give the site servers and your service provider a chance to synch before posting again. Recommend you "send" and then come back 10 mins later and check to make sure that it's been picked-up (received) by the site. Otherwise, you'll have information spread across several different threads, some relevant to your issue, but it will be missed because the multiple threads will have been deleted with that content. Two other threads, same title have been deleted. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
