butters Posted October 5, 2011 Author Share Posted October 5, 2011 Just did a pressure test. The intercooler is leaking at the end tank on the turbo side. I'm going to try bending it back and putting some jb weld on it. If that doesn't fix it it's time for a new intercooler. Link to comment Share on other sites More sharing options...
compsurge Posted October 5, 2011 Share Posted October 5, 2011 Keep us informed! Link to comment Share on other sites More sharing options...
butters Posted October 5, 2011 Author Share Posted October 5, 2011 Will do. Gonna let the jb weld dry overnight then pressure test it again at work tomorrow. Link to comment Share on other sites More sharing options...
compsurge Posted October 6, 2011 Share Posted October 6, 2011 I found my AVO TB-IC wasn't fully clamped. I don't know quite yet if that had anything to do with my issues. I'm still thinking my dual mass flywheel is bad. So I guess I will order a clutch kit and oem 06+ wrx flywheel Link to comment Share on other sites More sharing options...
butters Posted October 6, 2011 Author Share Posted October 6, 2011 Well the intercooler is holding pressure now but I have another small leak under the intercooler. I think it's coming from one of the hoses on the pcv but I'm not positive. I was trying to take it off but I couldn't figure out those hose clamps. Do I need some kind of special tool to get them off? My turbo inlet needs replaced too. I'm not sure if it's leaking or not but there is a tear on the underside right after the hose clamp. I took a picture of it but it's kinda hard to see the tear. I can't believe the dealership but it back on like this when they replaced my turbo. Link to comment Share on other sites More sharing options...
compsurge Posted October 7, 2011 Share Posted October 7, 2011 That inlet might be the cause of all your problems. It is very soft material and overtorquing it could very easily do this. Link to comment Share on other sites More sharing options...
butters Posted October 7, 2011 Author Share Posted October 7, 2011 Just bought another inlet. Should be here sometime next week and hopefully I'll get a chance to put it on that weekend. I'll let you know how it goes. Link to comment Share on other sites More sharing options...
butters Posted October 15, 2011 Author Share Posted October 15, 2011 Well after about 4 hours and a lot of cussing the new turbo inlet is on, but I'm still getting knock. I will pressure test it again on Monday to see if I have any leaks. I also pulled of the throttle body hose and the rubber piece between the hose and the hose clamp is ripped pretty good. I'm not sure if it is leaking but it needs replaced regardless. Can someone tell me what it is called so I can order a new one. Some pics of the old inlet and the ripped piece I'm talking about. Link to comment Share on other sites More sharing options...
compsurge Posted October 16, 2011 Share Posted October 16, 2011 throttle body hose donut? fredbeansparts might have one. Are you still using OEM TMIC or do you plan on upgrading? If so, you might want to order a AVO TB hose. I have an extra donut that I can sell you for a couple of bucks. LMK what the replacement cost is. Link to comment Share on other sites More sharing options...
butters Posted October 17, 2011 Author Share Posted October 17, 2011 Thanks. I looked on fredbeans but all I could find was the hose itself and not the donuts. Right now I still have the OEM top mount but I do plan on upgrading eventually. I was thinking about ordering the AVO hose but I'm going to run to the dealership today after work and see if I can just buy the donut first. Link to comment Share on other sites More sharing options...
compsurge Posted October 18, 2011 Share Posted October 18, 2011 pics of mine... Link to comment Share on other sites More sharing options...
VermontGT Posted October 19, 2011 Share Posted October 19, 2011 I've been tracking this thread with quite a bit of interest. I have the same symptoms as both of you - stuttering between 2-3k rpms at 40-50% throttle and up. Unfortunately I don't have access to any sort of datalogger at present so I can only wonder about my knock sums. The main reason I'm chiming in now is this: I recently replaced the turbo on my wife's 02 WRX and noticed the same problem with the rubber intake boot between her throttle body and intercooler. The thing is flipping destroyed. Worse than the pictures you posted. But I needed to drive it home from where I was working on it, so I threw it back together and am ordering a new one now. Anyway, where I'm heading here is that her car does not exhibit any hesitation on acceleration despite having a swiss-cheese intake boot. The thing just never develops any boost. I don't know if this is worth anything, whether a shredded boot should produce the same symptoms across different platforms or not, etc., but there's my .02 Link to comment Share on other sites More sharing options...
compsurge Posted October 19, 2011 Share Posted October 19, 2011 By no boost do you mean wastegate pressure or 0 psi? Do you own a laptop? If so, check out the vag-com cable and ECU Flash/Romraider/Liveview. Link to comment Share on other sites More sharing options...
VermontGT Posted October 24, 2011 Share Posted October 24, 2011 I assume zero psi since there's no way the intake can be pressurized with so many tears in that hose. Link to comment Share on other sites More sharing options...
compsurge Posted October 24, 2011 Share Posted October 24, 2011 The turbo is post hose. Zero psi would indicate no turbo or a massive post turbo leak. The boost pressure is read at the MAP sensor next to the boost control solenoid. The line feeds the MAP from the turbo housing. Link to comment Share on other sites More sharing options...
VermontGT Posted October 25, 2011 Share Posted October 25, 2011 Right you are. The holes are behind the MAF sensor, though, so it's strange that I haven't popped a lean code yet. Link to comment Share on other sites More sharing options...
