collier89139 Posted September 4, 2011 Share Posted September 4, 2011 I noticed that something seems to be cutting into my rotor on the front drivers side on my legacy. I think it is what is causing this metal noise. It is a brand new rotor and brand new pads. The other parts of the hardware are old. ANY THOUGHTS Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Share Posted September 4, 2011 Have you checked to make sure nothing is between the pad and the rotor? Link to comment Share on other sites More sharing options...
collier89139 Posted September 4, 2011 Author Share Posted September 4, 2011 it seems to be cutting the rotor close to the center ( hub area) Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Share Posted September 4, 2011 How much is it cutting in really bad?or a little? Link to comment Share on other sites More sharing options...
collier89139 Posted September 4, 2011 Author Share Posted September 4, 2011 really bad seems to be making a load noise while I drive it doesnt happen in reverse Link to comment Share on other sites More sharing options...
worknlikeadog Posted September 4, 2011 Share Posted September 4, 2011 Link to comment Share on other sites More sharing options...
Bigdaddy41301 Posted September 4, 2011 Share Posted September 4, 2011 I agree need pics. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 4, 2011 I Donated Share Posted September 4, 2011 Is it on the wheel or engine side of the rotor. If its on the back side (engine side), its probably the metal dust shield rubbing against it -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
collier89139 Posted September 4, 2011 Author Share Posted September 4, 2011 it is on the wheel side...I just put new rotors on 2 days ago and it is cut fairly deep.. deep enough thta you can run your hand across and tell there is a ridge i would post pictures but i live in Las Vegas and it is dark out and my camera is full of pics of strippers and hookers Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 4, 2011 I Donated Share Posted September 4, 2011 my camera is full of pics of strippers and hookers Sounds like you need to get a girl of your own! lol Check to see if anything is stuck between the pad and rotor -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
collier89139 Posted September 4, 2011 Author Share Posted September 4, 2011 wheel side Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 4, 2011 I Donated Share Posted September 4, 2011 you already said that -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
wengermi Posted September 4, 2011 Share Posted September 4, 2011 when i had brembos on my acura i had the same issue with new pads and a resurfaced rotor. it ended up being a seized caliper and the friction from the pad was over heating the rotor causing it to eat itself up. is the rotor turning blue or any other color? Link to comment Share on other sites More sharing options...
collier89139 Posted September 4, 2011 Author Share Posted September 4, 2011 i am not sure if the rotor is blue...what can u do about a seized caliper??? Link to comment Share on other sites More sharing options...
worknlikeadog Posted September 4, 2011 Share Posted September 4, 2011 Buy a new one Link to comment Share on other sites More sharing options...
TbirdMan Posted September 4, 2011 Share Posted September 4, 2011 you CAN rebuild it, but it may seize again and isn't really worth it. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 4, 2011 I Donated Share Posted September 4, 2011 Actually rebuilding a caliper is VERY easy and CHEAP. I bought a caliper rebuild kit (just a few seals) for $6 from Advance Auto Parts. 15 minutes of work and it was done. The trick to get the piston out is to blow it out with compressed air through the bleeder port. You can use a fine emory cloth to clean the piston after its out. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
collier89139 Posted September 5, 2011 Author Share Posted September 5, 2011 would a seized caliper cause the load noise i keep hearing from that side of the car? Link to comment Share on other sites More sharing options...
collier89139 Posted September 5, 2011 Author Share Posted September 5, 2011 if I do replace it should I do both sides at once? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 5, 2011 I Donated Share Posted September 5, 2011 I usually replace calipers in pairs. Its really a matter of preference though -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
wengermi Posted September 5, 2011 Share Posted September 5, 2011 also if a rotor is glazed it will cause it to squeal. you should pull the tire off and look at how the rotors look. Link to comment Share on other sites More sharing options...
jamesm113 Posted September 6, 2011 Share Posted September 6, 2011 Actually rebuilding a caliper is VERY easy and CHEAP. I bought a caliper rebuild kit (just a few seals) for $6 from Advance Auto Parts. 15 minutes of work and it was done. The trick to get the piston out is to blow it out with compressed air through the bleeder port. You can use a fine emory cloth to clean the piston after its out. I used a grease gun on my motorcycle to get a stuck piston out since I don't have a compressor. It made a mess though. Link to comment Share on other sites More sharing options...
400obw Posted September 9, 2011 Share Posted September 9, 2011 When you changed pads did you clean the caliper and use synthetic caliper grease on the slides and the brake pads? Don't overlook that the brake line can be soft and cause a brake to drag too which makes it seem like the caliper sticking. You won't be able to tell on the outside but the inner line gets soft and doesn't release the caliper. And yes rebuilding a caliper is easy and cheap. I didn't see anywhere but is yours a dual piston caliper or single? Link to comment Share on other sites More sharing options...
