lee07 Posted August 23, 2011 Share Posted August 23, 2011 My car is making slow ticking noise's when I turn and brake together like pulling into the garage. It doesn't make any noise when I turn but once I apply the brake's and turn it make's slow ticking noise's. It makes noise turning both ways. No noise when driving straight and braking. No ticking when just turning without braking. Only when turning and applying the brakes with it tick slowly. Not sure what it is. Maybe pad but it's got pad left and on tight. Backing plate is not touching but is quite close to the rotor. What do you think? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 23, 2011 Share Posted August 23, 2011 Drive faster...lol My first thought is a CV joint. Is the noise on both sides ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lee07 Posted August 23, 2011 Author Share Posted August 23, 2011 It was only when turning left but today I heard it when turning right also. It only makes noise when going slow like 2 mph. The front right axle was recently replaced. Link to comment Share on other sites More sharing options...
AZP Installs Posted August 24, 2011 Share Posted August 24, 2011 Hmm... Axle, LCA Bushing, Caliper Sticking, Bearing? Hard to diag w/o hearing it. -mike http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/133406601.jpg AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1(2971)| T-1 Certified Amsoil Direct Dealer "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
lee07 Posted August 24, 2011 Author Share Posted August 24, 2011 Turn's out to be an old rusted inside shim. It was stuck on the pistons when I lifted up the caliper. I removed it and now no more noise when slowly braking while turning. I Knew it had to be brake related. Link to comment Share on other sites More sharing options...
